ok ive got some drivers, 8inch 50 watt rms, usable freq. 68Hz to 4.5khz. i cant get any data for the qms qes and qts, or vas and resonant freq. how can i get this without contacting the manurfacturer, (unknown) or buying expensive equipment to test them myself??? help please, steve.. ..
you all laugh because im different, i laugh because youre all the same.. .. |
#2 |
Banned
You can't. Sorry.
#3 |
I once used the method from the Loudspeaker Design Cookbook and freeware with a laptop soundcard as a signal generator through an amplifier for larger current.
Basically, I measured the impedance per the LSDC at 5 Hz intervals from 10-40 or 50, then 10Hz from 50-100 then 20 etc (or whatever the intervals should be) and plotted them to get a visual of the impedance curve. I then used the added mass method (you could use the sealed box method) to get the new data and used the equations from the LSDC to derive the parameters. I never did measure Bl, though as that was a different set-up. This was a while ago, so I may well have left out a step or two, but I did just follow the LSDC. One of the equations in there (or maybe in the Weems book) was either wrong or I interpreted incorrectly. Once I found the error, the results were very close to the manufacturer's specs and Darren @PE's Clio measurements. If you're dealing with a complete unknown, I'd say its better than nothing. You would need the LSDC, a decent DMM and a PC with a soundcard (with a freeware tone generator). A standard known resistance of 10 ohm makes calibration easier. If there are additional comments to support or deny this as a valid method, please post them for my sake as well. Sandy. |
#4 |
Here's a link: http://sound.westhost.com/tsp.htm
I tried it but I'm not really good with math (the "sanity check" calculation would never be correct for me). Maybe you can try it and show me how you did it. |
#5 | |
diyAudio Moderator Emeritus
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.) |
#6 |
cheers guys ill have to look at wheather its worth it or just pay more for some new drivers that i can find the params for. thanks again guys, steve.. ..
P.S. any one know where i can get some 8inch 30 watt rms bass/mid drivers for under £15????? lol....
#7 |
You could tryPraxis
It measures T/S in freeware mode. It's quite easy to do as a script walks you through the steps. It support both added mass and closed box method. Ergo
Ergo ergo.esken@mail.ee |
#8 |
Did it Himself
You might as well measure the ones you have. You will need (for other general and audio stuff) the things you have to buy for measuring anyway. Plus you should really measure speakers that you buy even with published specs as there is always manufacturers tolerance and some can be way off.
#9 |
ill have a look at praxis, probly get anoyed and just dump them in a box and play around with ports and damping till they sound the best. cheers guys, steve.. ..
#10 | |
"This site gives off very confusing signals, one minute highly technical discussions that leave the truly interested learners wallowing in their own stupidity and the next finds it endlessly repeating old wives tales and cockeyed theories as fact." |
| Newbie small subwoofer questions | DSB91 | Subwoofers | 7 | 15th February 2008 02:12 PM |
| Theil driver in 4/2004 Hobby Hi-Fi - Anybody got the info? | Tenson | Multi-Way | 7 | 4th February 2007 11:18 AM |
| small kit amp recomentations for newbie | mp006ltk | Solid State | 1 | 21st November 2005 01:40 AM |
| Ported Enclosure Design w/o Driver Theil-Small Parameters | misterbobman | Multi-Way | 6 | 29th March 2005 03:06 PM |
| Page generated in 0.10746 seconds (79.52% PHP - 20.48% MySQL) with 10 queries |
