Best way to glue wood without clamps?
Old 29th September 2004, 03:30 PM   #1
mr_push_pull is offline mr_push_pull  Europe
Send a message via Yahoo to mr_push_pull
Default Best way to glue wood without clamps?
How to glue wood if clamps are out of question? More precisely, how to ensure that the angles are and stay right? And how do you do it, do you glue the sides to the top and bottom first and then the baffle and the back or all at once?
we all love a good ol' stereotype until it's against us
Old 29th September 2004, 03:34 PM   #2
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
mr p p,
Please tell us why you can't use clamps.
Cal
planet10 needs your help:
Let's help Ruth and Dave
Old 29th September 2004, 03:36 PM   #3
Originally posted by Cal Weldon Please tell us why you can't use clamps.
I haven't found a place to buy them from....?
I know about duct tape but I wonder how could I make 18 mm heavy MDF stick into place with that? After all, it requires precisions below 1 millimeter.
Old 29th September 2004, 03:49 PM   #4
till is offline till
Banned
screws
Old 29th September 2004, 03:53 PM   #5
Speakerholic
Cal Weldon's Avatar
As till said, your option is to use screws. You also have the option of removing the screws after the glue dries and filling the holes. If you don't like that idea, use heavy weights.
Cal
Old 29th September 2004, 04:06 PM   #6
Cal
I have to admit I kinda dislike the idea of having screws in my speakers, but if it is the only option... And above all, I'm afraid I won't be able to make the holes for the screws right and I'll ruin all that's been done till now. I guess I'll have to experiment a bit.
Old 29th September 2004, 04:13 PM   #7
dnsey is offline dnsey  United Kingdom
Why not make some?
Cut a few right-angled triangles from offcuts of your MDF, glue them up to make two strong prisms, fix one securely to a stout batten, and make the other adjustable using bolts, etc. Alternatively, you could use opposed wedges for adjustment and tightening
Old 29th September 2004, 04:18 PM   #8
Tazzy is offline Tazzy
Send a message via MSN to Tazzy
These could do the trick: Click the image to open in full size.
Old 29th September 2004, 04:30 PM   #9
phase_accurate is offline phase_accurate
There is some type of glues that works without much clamping. But I don't know its long-term behaviour.
regards
Charles
Old 29th September 2004, 04:34 PM   #10
chipco3434 is offline chipco3434  United States
... a Spanish windlass.
Wrap rope around the enclosure and secure as a loop. Insert stick in a bite of the loop around the box and start turning the rope, gradually increasing the tension.
Just like a tourniquet.
Best way to glue wood without clamps?Hide this!Advertise here!
Undoing wood glue...advice needed :( Glowbug Full Range 10 23rd December 2007 03:11 PM
for a wood chassis, is glue enough? riotubes Parts 3 6th October 2006 04:25 PM
Hot glue on wood case for mounting? Dominick22 Chip Amps 6 14th June 2006 10:12 PM
$2.99 for clamps at the House of Fools RAW Multi-Way 1 16th March 2003 12:37 AM
Calling Veneer Experts: Iron and Wood Glue Milzie Multi-Way 20 26th December 2002 01:09 PM
Copyright ©1999-2017 diyAudio
