I am liking what I'm hearing/reading about this driver and was thinking of buying a nice amount of them and building some speakers out of them. Maybe start with 1-2 drivers in a small bookshelf for my computer and move on from there. If I'm not mistaken, I'd be better off pairing these with a mid-woofer to help with the transition from the sub to the Tang, right? Maybe a woofer that will take care of 80-200hz or so, where the Tang is weak. This will allow the sub to not be localized as easily. I plan on making larger bookshelfs, possibly floorstanders, with this driver and would like to use the same mid-bass driver in them as well. Any suggestions?
Maybe something like this Tang that's on special for $15/each: http://www.acoustic-technologies.ca/...wa0640a6-w.jpg Or if you have any other suggestions, I'm all ears. The Tang W3-871S is 87db sensitive so I'd rather not need to have a lot of mid-bass drivers to even out the sensitivity issue. I'm thinking of using 2-4 of the Tangs per speaker when I build larger ones, possibly even 6. Thanks for any help! |
#2 |
#3 | |
Whats up with your hp? I´m mating the TB W3-871S with a Gradient W160AL8-ML-TL at the moment and I believe once I get the crossover right results will be marvellous. (XO-newbie) Cross the TB with 6dB (47uF) at the moment but I reckon it should be steeper to let it play more relaxed. Another not that "fruity" discussion: Woofer (not sub) to go with the W3-871S
jens |
#4 | |
#5 | |
jens |
#6 |
frugal-phile(tm)
Whatever you get, you want it to be quite extended on the top... i'm using a pr of vintage Coral 8" woofers per enclosure with mine (same baskets as the 8" FR you got from me Tim)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#7 | |
#8 |
I think JoeBob put long effort into picking a good match, although this is specifically an open baffle design:
http://www.diyaudio.com/forums/showt...833#post199833
Aerodynamics are for people who can't build engines. Enzo Ferrari |
| WTB a Tang Band 871S | joeybutts | Swap Meet | 14 | 19th November 2009 04:56 PM |
| I want your tang band w3-871s !!!!!!! | norman bates | Full Range | 0 | 15th September 2008 06:43 AM |
| Tweeter to Pair with 4" Mid-Bass Driver ? | bordins | Multi-Way | 2 | 4th April 2008 10:32 AM |
| A Pair of Tang band W4-1320SB bamboo driver | Bing Yang | Swap Meet | 4 | 4th January 2008 03:31 PM |
| Tang W3-871s as a tweeter with these? | mazeroth | Full Range | 10 | 13th December 2004 09:49 PM |
| Page generated in 0.18202 seconds (46.12% PHP - 53.88% MySQL) with 10 queries |
