Tweeter replacement for B&W DM330i
Unfortunately these tweeters (TP26) are no longer available.
Here are some specs, does anyone know of a suitable replacement? Thanks /Hugo :) |
Not an exact replacement, but with some work on the faceplate it can be mounted and looks very similar. Maybe B&W used the customized version of this Peerless tweeter :
Peerless DT 80 H Zozo |
Thanks Zozo
Looks like a good offer. I'll buy one and listen if it's doable. ;) /Hugo |
I think B&W make their own drivers for years. Hugo can't you buy a used pair for spare parts? Maybe the DM220 also works... If you go the peerless route, then I recommend to change both tweeters and do some tweaking on the x-over. |
Thanks Taco
Customer will be happy to pay for two tweeters but not for me messing with the crossover. I honestly wouldn't know where to start. If the Peerless sounds more or less Ok, both parties will be happy. You can call this a shame but this is the price I pay for not having a math head ;) If things sound awful, I’ll let you know and post the crossover schematic and we’ll see if someone can give some hints here. /Hugo :) |
We finally replaced the tweeter with a Peerless DT115 .
Sound is fine, a little too much high, but not worth messing around. Thanks for the help. /Hugo :) |
OOOoooooooh... they still look good don't they?
http://www.tazdevl.demon.nl/_temp/330_100.jpg The 100 and the 110 series share the same tweater ;-) |
| All times are GMT. The time now is 03:56 AM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
