Old 28th September 2004, 10:40 AM   #1
Raka is offline Raka  Europe
Raka's Avatar
Default Shelving pass filter-Active
I have one question about this filter, as explained in the Linkwitz site
www.linkwitzlab.com/images/graphics/shlv-lpf.gif
but I don't know which is the ratio between f1 and the gain G1. It can't be the standard 3dB, because the gain is user defined and can be whatever value you need.
If I want to compensate the BS, then a gain of 6dB is required, so f2 would be two times f1 (non inverting configuration), how can then compensate for a baffle step starting at 250Hz until the 20Hz?, do I need to cascade two stages?
What is beyond the speaker?
Old 28th September 2004, 10:55 AM   #2
BobEllis's Avatar
Look here: http://www.t-linespeakers.org/tech/b...stepcompo.html
It is the same math, just more thoroghly explained. SL seems to assume that his readers are more advanced than I am. The t-line page also starts from the midpoint of the step, I used that formula and got the repsonse that I expected.
Old 29th September 2004, 01:53 AM   #3
Davey is offline Davey  United States
Raka,
In theory baffle step correction should have a maximum adjustment of 6db....based on the 4pi to 2pi radiation change. Some systems may not require as much, but none should require more. (If you're referring to baffle-step correction exclusively.) A correction for a typical baffle width might be centered around 150Hz and the EQ would range from 100 to 200 with a 6db boost.
A 250Hz to 20Hz correction is 22db, and MUCH more than a simple baffle-step correction. This sounds like a compensation that might be used for a dipole roll-off or similar.
Davey.
Active High-pass filter for Horn Subs Eddie Wolve Parts 5 21st July 2009 05:47 PM
how to make a shelving filter? for FR pforeman Full Range 8 24th June 2009 02:24 PM
high gain 2nd order high pass active filter topology sreten Solid State 21 23rd March 2006 01:26 AM
active filter from rod elliot and sub filter questions wuffer Parts 0 2nd October 2005 01:12 PM
Active Band Pass Filter Design... xitronics Parts 8 6th June 2005 06:01 AM
Page generated in 0.07270 seconds (68.92% PHP - 31.08% MySQL) with 10 queries
