Hi there, this is my first posting and there are a few good reasons why I registered with a British audio board.
We are a three-piece band from Germany and we have experimented with equipment from the UK, especially in the bass. We have used TSE 118s copies and initially put Eminence speakers in them. That sounded terrible. Then we used Fane Colossus, which has been fine until recently when we came across some horncabinets with speakers in them that read 'G500' on them. Also the horncabinets are different from the TSEs as they have an inner resonance wall that goes in an angle rather than being round (scooped). Is there anyone who can tell me anything about the speakers ? What about the T-S parameters ? |
#2 |
Hello Saxoman
Welcome Aboard! A picture is worth a thousand words, and, would be helpful. For, I have no idea what speaker or cabinet you are refering to. Best Regards,
OMNIFEX |
#3 |
Here are some photos of the speakers . We found a label on one of the speakers which said Wembleyloudspeakers. Is that the origin ?
As I said the equipment looks like junk, but it sounds much better than our TSE118/Fane Colossus combination. We would be grateful if anyone could identify the speakers. Or maybe someone has the specs ....... |
#4 |
And another one
#5 |
Beyma?
UrSv Those who say it can't be done should not stop those who are doing it. |
#6 | ||
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#7 |
Ah, TSE118s, how many of those have I thrown in and out of gigs...
The Wembleys are copys of the TSE118s, (but then again just about every single 18 horn is a derivative of this, and I'm sure the Turbos were not the originals, just the best known), but with straight horn flare panels for cheaper construction. Drivers that work well in these boxes are the JBL 2226, and Precision Devices 1800/1/2, and a Fane 18" that has just slipped my mind right now...
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#8 |
Actually,
Celestion's frames always have their named embroiderd on the frame. It could be a Goodmans, for they used the same frame as Celestion. You may need to contact Celestion, for they will know if its theirs or not. Also, the cabinet it came out of, can give you a ballpark estimate where the speaker stands in the TS Parameters. If it is indeed Celestion, your looking at a QTS anywhere from 0.2 - 0.3, a fs around 33 - 30Hz, and a xmax of 3.25 mm If it's a Goodmans, I wish you good luck, for specs are hard to find on their speakers. I've also, noticed the recone date is 2001. Well, that frame was Celestion's frame in the 80's. So............. there's a good chance that speaker was reconed using a different brand all together. I remember seeing a few years back, a Fane cone in a Celestion frame on Ebay (The Frame was exactly like yours but black) stating, "Fresh Recone" You may find it better to find the reconer, for he will know the TS Numbers.
OMNIFEX |
#9 |
Perhaps you could post the same question in the Einsteiger section of www.pa-forum.de. Some people with lots of experience/knowledge about PA speakers post on that forum and you might get lucky. If the speaker is suspected to be of English construction, you might want to try the forum at www.speakerplans.com . The G also let me think it might be an older Beyma.
Martin |
#10 |
P. Audio usually uses blue cast baskets. You might have a look at www.paudio-europe.com. But otherwise I have no clue as to what this could be.
/Magnus
"Knowing what to do but not why is no use in a changing world" - The Art of Sound Reproduction |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| What makes Nichicon "muse"/"for audio" caps different ? | percy | Parts | 2 | 3rd October 2009 05:53 PM |
| Fostex "rated input" and "music power" | hugz | Full Range | 12 | 16th March 2006 04:33 PM |
| Some final pics of "Stacks" revisited and "Askew" with stand | Andy G | Multi-Way | 2 | 3rd February 2005 06:07 AM |
| Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? | Ignite | Multi-Way | 3 | 18th November 2001 08:42 AM |
| Page generated in 0.60618 seconds (17.77% PHP - 82.23% MySQL) with 11 queries |
