I want to desing a speaker enclosure around the SEAS P21RFX/P woofer and using the following formula, it gives me something around 10.6L which sounds strange to me. What am I doing wrong here? Vas = 48.3L Qts = 0.23 Vb = 15 * Vas * Qts^2.87 Regards, Marko Ramstedt Nebraska |
#2 |
This is Maximally flat alignment from memory.
For all sorts of ported box manipulations,use a modelling program www.linearteam.dk 'winisd pro' is the easiest one. Small driver and low Qts demands tiny box.... |
#3 |
That alignment is a curve fit by D.B. Keele of SC4 and QB3 alignments. While it works for low Q woofers such as the one you are using, it does not always give the best value. With the Keele Alignment, you get a bass cutoff in the mid 50's. With the Richard Small (of Thiele/Small fame) alignment (which WinISD uses) you get an even smaller box - ~7.6 liters
With your relatively high resonance woofer, you will want to oversize the box and tune lower. Try modeling a 28 liter box tuned to 38Hz with a 3" diameter x 11" port. This gives an Extended Bass Shelf (EBS) response that will squeeze more bass extension out of that woofer. You could also try a 20L box tuned to 44Hz wiht the same vent dimensions... The above examples assume no series resistance. With low Q woofers, the effect of adding the series resistance in the crossover and the output impedance of the amp ( together these raise Qts) is important, so don't forget to allow for them. Qes' = Qes*(1+Rs/Re), where Rs is the value of series resistance and Re is the DC resistance of the coil. Qts effective = Qes'*Qms/(Qes+Qms)
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#4 |
Thanks guys, I'll try for a larger box. Do you know of any good measurement programs for download and how would I utilize my notebook to handle the work?
-Marko |
| Soundeasy v14 TL enclosure calculations | Jimmy154 | Multi-Way | 0 | 14th March 2009 02:29 PM |
| Help me align this 15 in a vented enclosure? | mpmarino | Multi-Way | 8 | 4th August 2008 06:06 PM |
| Speaker enclosure calculations | cumesoftware | Multi-Way | 7 | 19th May 2008 12:58 PM |
| MCM 55-2421 Vented Enclosure? | cj.9 | Subwoofers | 2 | 11th May 2006 05:12 AM |
| Fb Enclosure tunning Vented | webleather | Subwoofers | 7 | 28th May 2005 12:27 AM |
| Page generated in 0.07464 seconds (77.09% PHP - 22.91% MySQL) with 10 queries |
