hi,
i got a couple of speakers from a friend that are about 5inches in diameter. the markings say 80 watts 8 ohms and not much else. i loaned my camera to my sister so i'll just describe how they look: the front are covered with grills. the back right below the magnet (where there should be the spider and where you should be able to see the back of the cone), is sealed with a metal cover. i've searched this forum on how to handle these types of speakers but have found no references. pls help: do they need enclosures or were they meant not to be in boxes? And can their T/S numbers be measured the same way as other speakers? thanks, would appreciate any help |
#2 |
can you see any of the back of the cone?
or does the enclosure go all the way to the basket edge? if it's the former then they're probably sheilded speakers from a tv or somat and will need a box to sit in the latter a sealed mid range and wont need the loading a box provides either way they can be measured just like every other speaker |
#3 |
hi synergy,
thanks for the quick response! it's the latter. the cone is not visible from the back. the magnet is exposed and messes up the tv picture if placed anywhere near it, so i guess it's not shielded. does this mean that they can be installed just about anywhere? (and no need to measure T/S bec. there's no box to fiddle with). thanks |
#4 |
no box to deal with but you'll still have to measure them for the t/s params and may find a frequency response plot will help in order to properly design a crossover for them
#5 |
Those are for mid range reproduction. There won't be any bass output.
| Promise not to laugh | Moondog55 | Multi-Way | 24 | 19th July 2009 10:40 AM |
| newbie with input tran. question and wiring question | imo | Solid State | 0 | 18th January 2006 10:10 PM |
| time for a laugh | chrisr | Tubes / Valves | 12 | 7th November 2005 12:56 PM |
| it makes one laugh | Artmaster | The Lounge | 17 | 24th December 2004 10:51 AM |
| newbie post, but hopefully not a newbie question | wiredcur | Solid State | 3 | 24th August 2002 10:49 PM |
| Page generated in 0.08448 seconds (69.81% PHP - 30.19% MySQL) with 10 queries |
