Looking for a nice 4" midrange, any suggestions???
Old 22nd September 2004, 04:50 PM   #1
cody6766 is offline cody6766  United States
Send a message via AIM to cody6766
Default Looking for a nice 4" midrange, any suggestions???
Hey all, I was directed over here from Elite Car Audio in hopes of finding a good 4" driver for my car.
I need it to:
work well in a sealed kick pannel
take 75w at 4 ohms or 35w at 8
Play from 200hz (12 or 24 dB) to 2khz (12db)
stay under $100-150 for the pair. (cheaper is better as long as the driver is good)
They will be matched with a Focal k1 6.5 mid-bass, and a Morel MT10 tweet. I'm running all active xovers, so the resistance isn't an issue. I listen to mostly Rock music, but enjoy some Jazz, Blues and the like now and again. I need something that can play loud as well.
Right now I'm running a pair of 4" mids that were made by Vifa for JBL. I bought them from PartsExpress, if that rings a bell. I'm happy with their sound quality, they just can't handle the power I'm throwing at them. Burning voice coil has plagued my car a number of time
Thanks a lot for your help!
More of a car audio guy but it never hurts to learn about the other side!
~cody~
Old 23rd September 2004, 05:28 AM   #2
Tim Moorman is offline Tim Moorman  United States
Default N
cody,
No idea how this might sound as I have no experience with this unit, but Peerless makes good value stuff, usually. Price is right. Check the first unit after Peerless, the "car audio", woofers, and finally CD division - #830516. The CSX 5" looks very good if you can carve up the door a bit.
http://www.d-s-t.com/peerless/index.htm
Also, have a look at the new Morel mid. Looks pretty high tech, though it doesn't go low enough to meet your bandwidth requirements, it has great power handling and covers a decade.
http://www.morel.co.il/
Available through Madisound, probably.
Tim
Old 24th September 2004, 04:57 PM   #3
TTT, any other suggestions? I've read some good things about Tang Band, and have had good results with both Morel and Vifa, how do those stack up against other ~$50 drivers?
keep em comming!
~cody~
Old 24th September 2004, 09:49 PM   #4
robertwb70 is offline robertwb70  United States
4.5" maybe? http://www.creativesound.ca/details.php?model=WR125S
"The appreciation of music is subjective.The reproduction of music isn't."-Bill Dudleston
Old 25th September 2004, 03:09 AM   #5
any power specs? Adire's reputation says more than enough, but I need to know if it'll work w/35w @ 8ohms or 70w @ 4ohms
~cody~
Old 25th September 2004, 02:06 PM   #6
Mats J is offline Mats J  United States
More often than not, that is a result of the amp clipping because its too small for the volume you want, so it wouldn't matter if the driver could handle 250W.
Old 25th September 2004, 02:35 PM   #7
KBK is offline KBK  Canada
Oh. yer looking for a cheap one. I've got some nice ones..but..they's kinda pricey.
Cheapies..hhmm....
stick to open baskets, vented structures, both spyder and pole being vented. Place it in it's own critically damped (0.5 or lower, in my experience) sub enclosure. anything with non vented structre or design tends to sound very constrained. pinched, etc. ucky! bad sound! bad! (smack..owww!)
as a possible choice, one of the smaller morels would work beautifully. However, that is a bit out of the price range you are looking for, and if it is to be a 90db sensitivity speaker, morel can't be your choice.
"Extraordinary claims require extraordinary evidence." - Carl Sagan. Sometimes the claims aren't extraordinary. Sometimes the weakness of men's minds are the culprit. Mass mentality has nothing to do with obviousness or truths.
Old 25th September 2004, 03:18 PM   #8
MarkMcK is offline MarkMcK  United States
If you are looking for Tang Band, then go to:
http://diyaudio.com/forums/showthrea...355&highlight=
The four-inch models are 40 watts RMS before burn out. I do not know what the power rating is on your JBL drivers.
Mark
Old 25th September 2004, 05:50 PM   #9
http://www.partsexpress.com/pe/showd...number=299-495
These are the Vifa drivers I have now. I'm giving them a good 2x their rated power (probably a little more because good car audio amps are almost always underrated), so I know I was looking for trouble. I'm almost positive the amp isn't clipping. I have my gains all set properly, and I'm not hearing any kind of distortion or other problems from my morel tweets that are playing off the other 2 channels of that amp (4 channel).
~cody~
Old 25th September 2004, 06:51 PM   #10
navin is offline navin  India
navin's Avatar
Send a message via MSN to navin Send a message via Yahoo to navin
cody i think i've been where you are trying to go. i dont know anything short of marcom (morel's car audio line used to be called macrom) that will work with such high power demands. too bad they are expensive but morel used to licence their voice coil from dynaudio at one time so they have good pedigree.
...still looking for the holy grail.
Looking for a nice 4" midrange, any suggestions???Hide this!Advertise here!
Midrange Suggestions bjackson Multi-Way 16 7th February 2013 11:02 AM
FS: very nice RAAL "FlatFoil" ribbon tweeters {NIB }, with custom made front plate yairf Swap Meet 3 2nd June 2009 09:25 AM
a nice application note about damping LC networks "snubbers" mirlo Power Supplies 7 11th November 2005 09:46 PM
Nice "Brown dogs", SO08->DIL08 adapters peranders Parts 3 3rd October 2005 09:29 PM
Copyright ©1999-2017 diyAudio
