Can anyone help me i am looking for a 55-1875 MCM 18" woofer box design. http://mcm.newark.com/NewarkWebComme...KU=55-1875&N=4 .
Thanxs |
#2 |
It would help if they gave T/S parameters for it. Without those, its a guess. All I can tell from the photo is that its made by Eminence.
#3 |
Sry bout that its the first one the 55-1875.
http://www.newark.com/product-detail...o_speakers.pdf . Thanxs |
#4 |
Email MCM tech support and they usually follow up the next day with the TS parameters.
Tim |
#5 |
Driver Properties
Name: 55-1875 Type: Standard one-way driver Company: MCM Electronics No. of Drivers = 1 Fs = 31 Hz Qms = 2.193 Vas = 404.9 liters Cms = 0.171 mm/N Mms = 154.2 g Rms = 13.7 kg/s Xmax = 4.4 mm Xmech = 6.6 mm P-Dia = 405.5 mm Sd = 1292 sq.cm P-Vd = 0.568 liters Qes = 0.46 Re = 6.8 ohms Z = 8 ohms BL = 21.07 Tm Pe = 400 watts Qts = 0.38 no = 2.528 % 1-W SPL = 96.18 dB 2.83-V SPL = 98 dB ----------------------------------------- |
#6 |
For a max. flat alignment, it would be 13.34 ft3 for an F3 of 31.2 Hz. In a 6th order alignment, it would be 8.46 ft3 for an F3 of 24.5 Hz.
Both of these are fairly large boxes for what you get. For info on 6th order alignments, and drivers that will give the same or lower F3's in smaller boxes, go here and check out the downloads/enclosures page. www.highefficiencyloudspeakers.com |
#7 |
what about the port hole. If i want the length to be 3/4 in. What would the diameter of the port be?
#8 |
Check here:
www.highefficiencyloudspeakers.com Go to the downloads page, and read the article on alignments. It gives you the formulas to calculate port sizes, at the end of the article. |
| "Box" design and bracing for open baffle woofer array | ryoshu | Multi-Way | 0 | 17th August 2008 06:07 PM |
| shoehorn a 15" woofer / design help | mercury_marine | Subwoofers | 13 | 28th January 2008 12:31 PM |
| help!!! design a T-line enclosure for the "wrong woofer" | ningures | Multi-Way | 4 | 7th October 2006 07:24 PM |
| Tiny 2-way design w. 6.5" woofer | Lomax | Multi-Way | 6 | 20th May 2003 07:15 AM |
| Page generated in 0.11372 seconds (65.66% PHP - 34.34% MySQL) with 10 queries |
