I am building an unbuffered non-inverting gainclone and was going to buy speakers for it. I have been look at the BR-1 at partexpress. Then I was thinking if I'm going to build stands for them might as well build speakers.
I have a drill, sander, and jig saw. I am willing to buy more tools if needed. I plan on doing DIY for life. I have little wood working experience but am quick to pick stuff up. That being said I am looking to build speakers to compliment my gainclone. I really don't have a preference on size, but would like to keep cost below $300. Any ideas or help would greatly be appreciated. Thanks, Matt |
#2 |
After researching horns and full range drivers, I found some projects that looks promising. I know I killed my budget but I keep telling my self it's an investment.
Fostex BK-16 Folded Horn http://www.madisound.com/BK16.html Sigular DIY from oris with the Fostex FX200. http://www.diy-systems.com/en-us/dept_10.html Also I have been eyeing the "Holy Grail" at http://melhuish.org/audio/DIYBX6.html I like the BK-16 the most because it's a kit. The gainclone I'm building is at 56w is that too much for any of the above speakers? I can lower if needed. Thanks |
#3 |
Making boxes is difficult without a table saw, router, and perhaps a radial arm saw (and for me is a pain even with these tools). One has to be very accurate and square to get neat boxes. It takes most of us a long time to accumulate all of the power tools required for a complete speaker-building workshop, and I encourage you to do so, but if you want to get started building soon, the cabinet kit is a good way to start. Bob Brines is a respected valuable member here and he has a great and informative website.... http://www.geocities.com/rbrines1/
He has several well documented projects and offers cabinet kits as well. For example http://www.geocities.com/rbrines1/ .
Benford's law of controversy - Passion is inversely proportional to the amount of real information available. |
#4 |
My proposal blows the 300 dollar budget, too, but you get a lot for the money. 2 Selenium WPU1505 woofers, 2 D250X compression drivers, 2 HL14-25 horns, and 2 ST324 supertweeters, total $398.50.
Cross over to the mids at 800, and to the tweeters at 5k. If a few more bucks could be found, instead of the HL14-25 horns, get a pair that would allow a 500Hz crossover, and it would be even better. Use a 6th order alignment, and you can get a 28Hz F3 in 3.59 cu. ft., all in glorious high efficiency. Check it out here: www.highefficiencyloudspeakers.com |
#5 |
I would point you to the Ed Frias AR.COM kit. Nothing beats it at this price point. Of course this is my opinion. I have built seven pair, compared them to Paradigm Reference and B&W--AR.COM rivals both.
#6 |
Banned
i doubt a chipamp is ideal for (high) efficient speakers like horns. This is my impression at least with music perfomed with acustical instruments.
#7 |
The "Afterburner" is a simple and cheap design from Thorsten Loesch's site. Sounds like an interesting design to play with.
http://www.fortunecity.com/rivendell...terburner.html FWIW, Dr.F. |
#8 | |
#9 |
The one and only
My own impressions is that the high-efficiency full-range kind
of speakers like gainclones better if you insert some output resistance at the output of the amp, say 1 to 4 ohms, and operate the amp with a lot of the open loop gain thrown away. There's a schematic in the pass labs section under "diy progress report" as I recall. The higher output impedance allows you to build some shelving EQ networks, aka Baffle Step Correction also.
#10 |
The one and only
Oh, here it is:
www.passlabs.com/np/GC-VAR-INV-FDBK-1a.pdf and here: www.passlabs.com/np/GC-VAR-BAL-FDBK-1a.pdf |
| Are my Speakers efficient enough for my Amp? | SigloOne | Tubes / Valves | 3 | 7th May 2008 05:55 AM |
| Most Efficient Speakers ? | EdT | Multi-Way | 6 | 18th August 2007 11:55 PM |
| Efficient speakers for 7Wish | matthew2456 | Multi-Way | 13 | 26th August 2006 02:58 PM |
| Are my speakers efficient enough for tubes? | alexmoose | Tubes / Valves | 83 | 19th May 2006 06:31 PM |
| Page generated in 0.14136 seconds (69.22% PHP - 30.78% MySQL) with 10 queries |
