Old 21st September 2004, 05:13 AM   #1
Default stupid port question
I am building a box which will need a port with a bend it would be easier to run it down the inside wall & across the bottom with the opening being one diameter away from the other side .
The rule of ports being at least 1 diameter away from all surfaces in a box
Does this apply just to the entry& exit only or does it apply to the whole body of the port as well thanks
Old 21st September 2004, 06:01 AM   #2
Artmaster's Avatar
Send a message via ICQ to Artmaster Send a message via MSN to Artmaster
hi busterno1!
i's should be the same diametr lengthwise your port, but be sure about spurious response is will not show up as well. I had lot of these problem.
another way - making exponential form of port. round, rectangular, square profile...
lot of formulas, lot of version, but anyway you have to do experiment first.
Artmaster live in www.artmaydan.org.ua
Old 21st September 2004, 06:09 AM   #3
Bill Fitzpatrick's Avatar
The exit and body can be anywhere, even outside of the enclosure.
Another stupid question! Dxvideo Chip Amps 7 20th May 2007 03:46 PM
Stupid cap question... Bogie Solid State 8 6th September 2006 10:55 PM
Stupid question Leolabs Everything Else 2 8th July 2006 02:09 AM
A stupid question MaXiZ Power Supplies 1 2nd June 2005 10:04 AM
Stupid cap question jag Pass Labs 4 19th October 2002 08:26 PM
Page generated in 0.08161 seconds (66.01% PHP - 33.99% MySQL) with 10 queries
