#11 |
bz:
Can't thank you enough for taking the time to do that test. You've definately change my line of thinking for my active cross over. Of course all results will be posted here =). |
#12 |
Remember that everything that goes into the emu10kx DSP is resampled to 16bit/48kHz format.
#13 |
Yes, of course. I do not expect professional studio-level hardware for $45.00 but I hope to learn to build speakers worthy of an upgrade to the source electronics. The hardware and software engineers at EMU made excellent choices in terms of performance and cost of implementation, see the links to their patents on the kxproject website for more information. The system described in this thread does represent extraordinary value and very good performance, so let us not discourage people from trying it.
From this document... http://people.freenet.de/kxdev/docs/...1-overview.pdf ASYNCHRONOUS DIGITAL AUDIO RECEIVERS We designed the EMU10K1 to receive digital audio directly from devices such as CDROM and DVD drives. However, the sample rate of compact disc audio is 44.1 kHz, and the EMU10K1 output sample rate is 48 kHz. Due to manufacturing tolerances and drift, the clock frequency of each compact disc player differs slightly. Even if the output sample rate were also 44.1 kHz, the slight differences in clock frequency would cause the relative phases of the input and output sample rates to drift over time, eventually resulting in repeated or dropped samples. It is possible to force the clock frequencies to be exactly synchronous by using a tracking phase-locked loop, or PLL, rather than a fixedfrequency oscillator. Professional recording studios distribute a master clock to all interconnected digital audio devices, which derive local clocks from the master. This guarantees synchronicity of all digital audio streams. This approach is expensive and difficult, requiring PLL-based synchronization capabilities in all digital audio devices. Devices that cannot synchronize to an external clock source must become the master clock source. This is a distinct disadvantage as there can only be one master clock at a time. A better solution is to use sample rate conversion to resolve the incoming sample rate to the output rate. This requires a sample rate detector that continuously updates an estimate of the asynchronous digital input rate. The sample rate estimate maintains a phase accumulator that controls a 16-point Smith-Gossett2 sample rate converter. Such an asynchronous sample rate converter avoids the cost of a tracking PLL and provides support for multiple, simultaneous asynchronous audio streams. The EMU10K1 can support three simultaneous asynchronous stereo streams using high-quality asynchronous sample rate conversion.
Benford's law of controversy - Passion is inversely proportional to the amount of real information available. |
#14 |
back a bit, m0tion launched a question and bzdang was kind enough to provide some inspiration. i wonder if bzdang could take a second shot and help me find the end of the string so i start in the right place?
here's a goal statement: add room correction to a home theater setup using an 'htpc'; and i would like to do this in 2parts: 1. add low frequency correction, and possibly include the type of subwoofer compensation (an integrator) to drive the sub below it's resonant frequency as in the bag end elf or the esp module 2. add mid/hi correction (perhaps better called eq) to compensate some for the ceiling speakers my current configuration is as follows: 1. 7.1 setup: 2 front, 2 side, 2 rear, center channel, subwoofer 2. sony dvd feeds a lexicon dc1 and then into a parasound 6ch amp, a crown d60 is udes for the center channel, and a yamaha amp is used for the subwoofer. a motley collection to be sure, but it is what it is. 3. did i mention that for marital safety, the speakers are in the ceiling: partsexpress 29.95 a pair -- 6" woofer w/a center mounted 1/2" dome devil a few statements about my choices: 1. the stuff came by way of favors owed to me (some favors were big) 2. the speakers in the ceiling -- well that means no cables on the new rug. but actually, some lexicon engineers said that if i kept all the speakers and all the amps the same, i would have a coherent sound. better speakers, better amps, better sound, but it was a place to start and it fit the budget. so now, to the question and the search for the end of the string: i've seen the threads on brutefir, drc, and the new module from patrick cazeles (acxo). it seems the ingredients are all here but i'm not sure where to start. from a hardware perspective though, it seems that (assuming i could understand and get all the software to work) what ineed to do is sort of like this: 1. feed the 7 channels of output of the lexicon into several audigy cards 2. get the room correction work on the ceiling speakers (using them full range) 3. and then go to the amps does this mean at least 3 and 1/2 audigy cards? 4. take the front outputs from the lexicon, before the room correction, and derive a signal to feed the 'bag end emulator'; the emulator is the integrator circuit and something to eliminate the mids and highs. i would follow the strategy used by bag end 5. make this work 6. then do low frequency room correction does this mean another audigy card? then i remove the parasound/crown and do chip amps, and remove the sony with an internal dvd drive on the pc. this should take, what, a weekend? am i finding the end of the rope, or am i pi..ing up the rope? some clear thinking here would certainly help me out. if this is at least feasible, i'd break this down more clearly into real portions to fit together and be able to get done a little at a time. anyway, thanks for hearing me out |
#15 |
Oh man I am swamped this week with work but here are a couple of things to ponder and look at.
First, I haven't done much with home theater setup, mostly I listen to stacks of old jbl drivers in diy systems, so I can only give some clues based on my limited experience. I haven't learned anything yet about drc, but my favorite audio engineer has known the man at www.etfacoustic.com for around twenty years and respects him so give that a try. And I don't own one of the newer 7.1 capable audigy2 cards yet so I can't test to see how things work. But the latest version of kxproject drivers is in beta and has initial attempt at support for 7.1. If it works, you should be able to play dvd 7.1 surround sound within your computer and route all of the channels directly into the dsp soundcard for processing without going analog until you hit the lineouts to the amps. I assume that the ceiling speakers have passive crossovers, else you're going to need alot more channels and amps! Regarding the sub, if it goes too deep it may annoy your wife, just my experience, mine tends to be underwhelmed by such things. You may find that it all works quite well with room correction and a 24db/oct dsp crossover on the sub (which is included with kx). I'm told bass traps are good things as well, and you can make your own. Here's a link to the basic a2 card, no need to get anything expensive, a white box oem version will do. Note that the Audigy LS soundcard does not have the 10k2 dsp chip and is not useful for this purpose. http://www.creative.com/products/pro...ct=10653&nav=2 You should be able to get it all running quickly on a weekend, but I imagine it will take longer to measure the room interactions and tweak the system. I'm out of time tonight but will be happy to help out.
#16 |
This is some bodaciously awsome stuff. Naturally, the first thing I think of is wrapping up the C++ API as a Python extension. :-)
The Audigy folks should be paying you big bucks. Imagine how many sound cards people like me will fry and replace with new ones. Let's hope CTL doesn't pull the rug out from under you too often. Okay, if this is a hopelessly moronic question, I'm sorry. Once the DSP is programmed, what does it need for life support? Asking the question the other way, how much of the PC could you remove and allow the sound card to keep functioning as, for example, a crossover component?
Davy Jones |
#17 |
First I have to correct my earlier post, I was reading the support forum tonight and it appears that the 'value' card is not a good choice to use with kxproject drivers.
So for 7.1 applications you should look at the audigy2 ZS - - http://www.creative.com/products/pro...4&product=4915 For 5.1 or six-channel active crossovers the inexpensive audigy1 and 2 cards will do nicely. Read the forum for up to date info! http://www.driverheaven.net/forumdisplay.php?f=74 I'm just a humble user of the technology. After watching my coworkers use a omnidrive and then some audio dsp development kits, I became interested in the technology. I suspected that the audigy soundcards were waking up empty and getting loaded with their software on boot-up, just like most any dsp does, so I searched for 3rd party drivers and found the kxproject. It's a device driver with a graphic user interface that lives in the tray. It still works if you shut down the UI, the work is all being done on the soundcard, sort of like a geforce video card where 3d transformation and lighting is being done in hardware. No load on the cpu except for your media player if one is being used. External audio sources just run thru the soundcard without any work at all from the computer. You can run Ironcad and Martins mathcad sheets and play iTunes and snipe on eBay all at the same time without getting sound glitches. It can save configurations with a filename, and it also remembers the most recent config. and reloads it on startup. The hornguy goes bananas when he visits - add a notch at 8k! wider! a little lower. now boost the level on the tweeter, more, now make a broad peak at.... Been using this with an rca1428b, a hda high-eff. 10" midrange and lab12/uglybox, and it's just startling how quickly one can tweak it into verygoodness. I can change over and run my TL 2way in 30 seconds more time than it takes to move the speaker wires to it, because I saved the settings. I can cure the vile fostex drivers with instant bsc and midrange correction. I'm such a rookie at speaker design and building, but now I can do more learning in one weekend than a whole month of messing with passive networks. cheers from the kxproject evangelist
#18 |
Now if only the kxproject worked in linux =)
#19 |
bz:
I just got my audigy 2 and installed KX. I downloaded UFX and that gave me the 2nd and 4th order crossovers, but I was wondering where you got some of the other plug-ins like baffle-step and the tweeter phase plugins? I haven't been able to find them. |
#20 |
Hi, great news that you're giving this a go.
I got the baffle step by using 'EQ P1 (Mono)', selecting 'Hi S-shelf' from the pull-down list, and setting the gain knob negatively to cut above the bs freq. The BW knob is, I think, a variable slope control, it looks good to me at around 1. Frequency setting depends of course on baffle width. I use another P1mono to attenuate the tweeter and flip its phase if required (there's a little phi? gizmo above the main level control on the P1mono). For time-alignment someone on the kxproject forum wrote me a 'simple delay' which I use and have a zip file around here somewhere. Send me a hotmail address and I'll mail it to you (or anyone, the fellow included source code in case we wanted to modify it.
| Prototyping with SMD | ezkcdude | Digital Source | 6 | 23rd May 2006 12:39 PM |
| Instant voltage and current circuit? | CWChang | Solid State | 3 | 19th January 2005 03:42 PM |
| Page generated in 0.14618 seconds (84.88% PHP - 15.12% MySQL) with 11 queries |
