Old 23rd June 2002, 01:04 AM   #11
Oz_Audio's Avatar
Andrew
Yes you got the crossover correct, all speakers are wired in series (1/2 the nominal impedance with a 3dB gain). The woffers are direct wired with no filter so they run full range and the tweeter has only the 1 cap. This works very well in this design and very simple to construct and change if need be.
The cap I use is a Crescendo 10uf from North Creek Music. I will try there suggestion of bypassing caps in the future. Bypassing is using higher voltage, smaller unit caps to make up the correct value. In this case, I could use the 10uf and add a 800v 0.1uf or use a 6uf, 3uf and a 1uf. Check out their web site, interesting reading.
Oz
What would you recommend? bjackson Chip Amps 0 21st November 2005 05:17 PM
what do you recommend pd0019 Multi-Way 0 23rd February 2005 07:40 AM
Recommend a kit for me! Frank Z Tubes / Valves 11 8th October 2003 12:43 AM
Can you recommend me. jleaman Solid State 1 26th February 2003 11:50 PM
How many µF do you recommend for this amp? hugobross Solid State 3 29th September 2001 01:39 PM
Page generated in 0.06708 seconds (64.61% PHP - 35.39% MySQL) with 10 queries
