Hello,
I have been looking at the different sensitivity ratings and wondering how to compare them. For example, An 8 Ohm woofer with sensitvity of 86 dB (1W, 1m) And a 6 Ohm Tweeter with sensitivity of 88 dB (2.83V, 1m) Is there a formula or something to convert the 2.83 V rating into 1W, 1m)? Thanks in advance, Graham |
#2 |
Banned
I believe it's Ohms law, or a derivitive therof. The voltage required for one watt is the square root of the impedance load; 8ohms= 2.83v. 4ohms =2 volts; 6 ohms =2.44 volts, etc.
But what really matters is comparing everything with the same voltage, not wattage, as an amp is a constant voltage device and all the drivers in the system will see the same voltage, not the same wattage. In your case the 8 ohm driver is getting 86dB/2.83 v, the tweeter 88dB, so the tweeter may have to be padded by 2dB to match the woofer. BUT- woofers seldom actually get their rated SPL broadband, it's usually measured as an average, so even more padding may be required. |
#3 |
Thanks Bill, very helpful.
| Matching speaker sensitivities | Khron | Multi-Way | 9 | 2nd August 2005 12:56 PM |
| Input sensitivities of older equalizers | murat | Solid State | 4 | 10th March 2005 05:12 PM |
| Input sensitivities of older equalizers | murat | Everything Else | 0 | 8th March 2005 05:23 PM |
| sensitivities of amplifier configurations | metebalci | Tubes / Valves | 8 | 24th December 2004 12:36 PM |
| Is this how to compare speaker sensitivities? | Datoyminaytah | Multi-Way | 7 | 23rd August 2004 12:48 PM |
| Page generated in 0.07074 seconds (65.78% PHP - 34.22% MySQL) with 10 queries |
