BillFitzmaurice said:You can go smaller....Realistically that should work fine, as room lift below 30 Hz should fill in the bottom end nicely anyway.
I hope so. my room is not large by american standards (about 12 ftx 24 ft with a 8.5 ft ceiling) and i do have 4 of these woofers. I was thinking of using 2 of them in 3 cu. ft. TL and 2 of them in 3 cu. ft. sealed boxes.
one unrelated question. I have a stereo power amp (that can be bridged if I so desire). i can see 3 options:
1. bridge the amp (carver m1.0t) and run all 4 woofers in mono
2. run 2 woofers off each channel in dual mono - the signal the amps will be getting will be a mono signal from the LF output of my HT/AV Marantz SR7000.
3. bypass the LF filter on my HT/AVR OR take a stereo signal feed from the preout of the front channels and then use 2 seperate active XOs that sum left and right into mono as well. so now one has 2 mono signals at 2 different frequencies (say 100/120Hz and 60/50Hz). Feed one mono signal into one channel of the power amp and feed the second mono signal to the second channel of the power amp. run the TLs XOed at 100/120Hz and the sealed subs XOed at 60/50Hz. sounds complicated?
MJK said:Try my alignment tables for this 4:1 taper and see how close the geometry matches Bill's recommendation. Try a few different higher taper ratios to see if you can shrink the enclosure volume.
will do that. i could not find the link for the spreadsheet on your website. i will look harder.
MJK said:There is a link on the opening page labeled TL alignment tables. It is a "pdf" document that describes how to derive a TL geometry with a few simple calculations. There is no formal worksheet or spreadsheet involved, only a calculator is required.
You are a darling. I spent the better part of my bandwidth dowloading a 12MB file called Math Cad. Yikes! I will look at the PDF tom (friday) as I dont have a printer where i sit today. thanks for sending me on the right track.
MJK said:I could not find any claim that high Qts drivers were prefered in TLs. Where specifically did you find statements in the AES paper that high Qts drivers are superior?
Two pages of posts yet to read in this thread so someone may have commented already... what George said was that with a higher Q driver you can get more efficient bass. He said nothing about better. I don't recall whether he said it in his paper, but it was certainly a comment in his original presentation.
The B139 which was the basis on many of the successful classic designs has a Q of 0.37.
I consider 0.3-0.4 to be medium Q.
dave
BillFitzmaurice said:Bailey's 1972 design used a driver with a Qts of .6
Bailey's article does not say what Q the driver was, but he did use a KEF B139 (older racetrack version). The Q od the replacement driver, used in the same boxes by KEF, is speced at 0.37.
dave
Hello all!
I decided, that I will try to do TL.A lot of information I found at t-linespeakers and quater-wawe.At the begining I have in mind,that I should use mathcad worksheet,but it was to complicated for me(first year of secondary school ).Than I found at the those 2 sites(forum also) very understandable instructions:
* make the line length ~ 1/4 the wavelength of Fs (1/4 wavelength will be the F3 point)
* taper the line from 1.25 - 2 Sd down to Sd at the port
* after building it, stuff the line -- increasing or decreasing the stuffing till it sounds right. Add if the line is too "boomy", reduce if its too lean. The stuffing increases the length of the line (by slowing the speed of sound down to .7-.9) and (hopefully) damps out higher frequencies
(from www.t-linespeakers.org)
Then I found "Alignment_Tables.pdf", where are clearly described all
TL aligments...
I want to say "thanks!" to both authors,because searching on the net could take me hours nad hours of reading unuseful information...
Dean
TL aligments...
Dean
MJK said:Navin,
Sorry, can't find the link - am I being blonde? Anyone...
Cheers
- would Qts affect response in a TQWT?
