Old 19th September 2004, 05:14 AM   #11
bzdang is offline bzdang  Canada
bzdang's Avatar
Originally posted by BillFitzmaurice
The best damping material is high density rigid fiberglas but it's hard to find and nasty to work with; inch thick high density polyester furniture batting is a good inexpensive second choice.
Fiberglass ceiling tiles, vinyl one side, around 1/2" thick nasty fiberglass, available at home depot.
Used office-divider panels are also fiberglass, you get two panels per divider.
And all are extremely effective at absorbing sound from power tools and compressors in the workshop/garage.
Benford's law of controversy - Passion is inversely proportional to the amount of real information available.
Old 19th September 2004, 09:57 AM   #12
Geek's Avatar
@BillFitzmaurice: Ok, did the params. A wee lower efficiency though.
Old 19th September 2004, 01:27 PM   #13
Banned
I don't know how you're getting that response; something isn't right at all. I'm getting a much flatter response with 105dB sensitivity. Show me your input parameters.
Old 20th September 2004, 10:46 AM   #14
Geek's Avatar
'k
The over large VRC, LRC and TAL are simulating free space.
Old 20th September 2004, 12:29 PM   #15
Banned
Many errors. The Sd is off by a decimal point, should be about 206 cm/sq. Es for 1 watt= 2.83 v.
Vrc and Lrc should be 0; for a rear horn you don't use the 'rear chamber' as the 'rear chamber'position is swapped to the front where the cone fires directly to air, so there is no rear chamber. The Vtc is going to be the volume of the actual rear chamber that the rear of the cone faces, in this case at least 1000 cm/3. Try these alterations and you'll see a far different result.
Old 20th September 2004, 11:33 PM   #16
Geek's Avatar
Ok, I shall correct all but the Sd - it is correct (see attached)
Old 21st September 2004, 12:24 PM   #17
Banned
The Sd is 206 sq cm, not 20.6. The cone radius is about 8 cm, that makes its area 206 Cm Sq, give or take. You'd find an Sd of 20.6 in a two inch driver.
Old 26th September 2004, 11:11 AM   #18
Geek's Avatar
D'OH! My bad
I shouldda been smart the first time and used my converter program.
Here attached is SPL with corrected values. Look better?
Old 26th September 2004, 11:13 AM   #19
Geek's Avatar
I also changed the design from exponential to conical - more practical
Old 26th September 2004, 01:11 PM   #20
Banned
Much better, and the conical thing works too. Plus, when it comes to actually figuring the geometry conical is very easy to work with.
My 103E Rear loaded horns shporsche Full Range 17 15th July 2009 11:16 PM
Dampening in Tapped Horns?? atilsley Subwoofers 25 20th June 2009 08:24 AM
Rear-loaded horns: disadvantages? Taterworks Full Range 4 3rd October 2007 05:22 PM
Resonance in rear horns Jaime Full Range 1 2nd March 2007 10:10 PM
Page generated in 0.13270 seconds (68.38% PHP - 31.62% MySQL) with 11 queries
