Old 18th September 2004, 10:13 AM   #1
Ultima Thule's Avatar
Default Measuring phase & impedance w. PC soundcard?
Hi all,
I have started a new small 2 way loudspeaker project.
The drivers I had around are older Dynaudio D-28 AF and Peerless 130 MF 26/90 SP.
anyhow..
I would like to perform some measurments and measure impedance and phase over the audio range.
It would be nice if I could measure the phase both electrically at the loudspeaker connectors and with a microphone.
Does there exist any SW (preferably freeware) which use the PC soundcard?
I guess such measuring needs some kind of jigg with a resistor and perhaps a small amplifier which I can build myself then...
Any suggests?
"If transistors are blueberries and FETs are strawberries, then tubes must be.. pears"
Michael 29th January 2010
Old 18th September 2004, 10:46 AM   #2
Hello,
Speaker Workshop can measure impedance, phase and frequency response using the soundcard in a PC. It’s free, although quite complicated to set-up and use. You can download it here:
http://www.speakerworkshop.com/
A very through manual can be downloaded here (6.6MB):
http://www.audiodiycentral.com/resou...nual%201.0.zip
A jig isn’t required but using one is much better than soldering cables. The Wallin jig is the most popular:
http://www.gti.net/wallin/audio/jig2/jig2.html
An external amplifier will probably be required as almost all sound card do not have internal amplification, other than for driving headphones. I built a Gainclone-type amplifer and a microphone pre-amp into my jig's case to reduce cable clutter - it works very well!
Nice one,
David
Old 19th September 2004, 04:21 AM   #3
Hmm, I had no problem getting it Speaker Workshop set up and running once I knew what I was doing. I also have no problem measuring impedance without an external amplifier. I use an SB Audigy2. The hardest part was getting the right settings to make the stupid sound card work in full duplex mode. For measuring acoustic response, I usually use the amplifier I plan to drive the speaker with, so I am really measuring the transfer function of the entire system, not just the loudspeaker.
Old 19th September 2004, 10:01 PM   #4
5th element's Avatar
I use speaker workshop and the wallin jig for impedance measurement and to measure xover parts. It works really well.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Soundcard and Mic for measuring. champ222 Multi-Way 20 17th September 2010 06:46 PM
Measuring Phase Margin davidallancole Solid State 4 19th December 2007 06:18 AM
Which soundcard for KX Project and measuring speakers with a Behringer ECM8000? mazeroth Multi-Way 1 28th March 2006 08:22 AM
Software for measuring speakers, but also able to calibrate soundcard respons Nielsio Multi-Way 3 2nd February 2003 11:38 AM
Page generated in 0.09975 seconds (69.69% PHP - 30.31% MySQL) with 10 queries
