I recently designed and built a 2-way bookshelf speaker project. I'm thrilled with the results. They've replace my NHT SB2s. Their overall clarity, detail, and soundstage have thoroughly impressed me. Their one weakness is a bit of bass deficiency (+/- 3dB at 67 Hz). I had a sub going into the project, so this didn't bother me too much. Here's a brief design description in case it inspires anyone:
Drivers: Peerless 850122 Vifa XT19 Approximate volume of enclosure: .52 cu ft. External Dim of enclosure: 9.5"x10.5"x14" Material: 3/4" MDF Crossover: 4th Order Linkwitz-Riley at 2700 Hz (this avoids distortion in the Vifa and a bit of unevenness in the Peerless). I offset the center of the tweeter 1 inch from the center of the midrange. One brace (3x8) was attached to the back and sides. The box was sealed using polyurethane glue. The drivers were flush mounted. Most materials were purchased from Madisound; they were great to deal with. Total cost was about $350. I also made my own stands for them using some of the leftover MDF and PVC pipe. I connected the bases across the pipe using 3/8" all-thread rod. They are sand filled, attached to the PVC with polyurethane glue, and caulked to ensure a tight seal. They're mated with a HK DVD101 and a NAD C370. I'm very satisfied with the results of my first project. |
#2 |
pics please
Glad you are thrilled with the results. Any BSC, impedance correction, etc I am interested in any details. I cant afford to do your project but the details may help me with my own. |
#3 |
If you are willing...
I would appreciate details on the crossover you used. I presume a vented box? If so - what was your tuning freq. Thanks, David. |
#4 |
I actually used a sealed enclosure (thus the reason for the lack of bass). I wasn't worried about bass response and the ideal port would have been quite large, so I bypassed it.
I'll post details in a day or two... |
#5 |
Crossover is attached.
#6 |
Banned
pic's?
| Large Bookshelf/Monitors | Big Kev ! | Multi-Way | 1 | 19th May 2009 05:24 AM |
| Hi-End Sealed MTM Bookshelf Design? | treytexag | Multi-Way | 35 | 15th July 2008 07:34 PM |
| Vifa P17SJ and Vifa D27TG Large Bookshelf MTM | rwo | Multi-Way | 7 | 24th February 2008 04:47 PM |
| bookshelf design around foster ribbon | aleexman | Planars & Exotics | 0 | 19th December 2007 04:06 PM |
| Fostex fe167e bookshelf design | nacho1966 | Full Range | 20 | 17th September 2007 07:55 PM |
| Page generated in 0.11125 seconds (66.83% PHP - 33.17% MySQL) with 11 queries |
