Old 16th September 2004, 08:34 PM   #1
gary f is offline gary f  Canada
gary f's Avatar
Default Morel MW 144, best small woofer??
Hi
I just had a look at the Morel MW 144 5" woofer in the madisound catalog. The frequency response is flat up to 8000 Hz!! even 30 deg off axis.
Is anyone ever used this unit? It looks real good on paper. Looks very well suited for a first order configuration. Any experience?
F
Old 16th September 2004, 08:48 PM   #2
gary f's Avatar
Freq resp
Old 17th September 2004, 03:39 AM   #3
You sure that's 30 degrees OA? I wonder how the distortion is, up that high.
Old 17th September 2004, 09:20 AM   #4
planet10's Avatar
Default Re: Morel MW 144, best small woofer??
Isn't it quite inefficient?
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th September 2004, 02:32 PM   #5
gary f's Avatar
"Isn't it quite inefficient?"
Well, 88 dB sensitivity is not so bad. Of course, I would like 92 dB but many small woofers are less efficient (Seas W12= 85 dB)
Of course, frequency response is not all, that's why I am wondering if anyone used these or other Morel small woofers to know if they sound good...
F
Old 27th September 2004, 02:48 AM   #6
just another
wintermute's Avatar
I've been thinking about using two of these with a morel DMS37 in an mtm config for a while.
Time is a major problem for me, and I have not been in here for quite a while, but listening to my existing speakers lately has me thinking I should make some time
I've been told that if you flush mount the tweeter, and surface mount the mids it will be properly time aligned too....... and very good with a 1st order crossover...... try modelling two in (I think) a 10L sealed enclosure and see how you go (you will most likely decide you need a sub as well)
edit: try this for slightly more info http://www.eltimaudio.com/products/m...0datasheet.pdf
Tony.
Any intelligence I may appear to have is purely artificial
Some of my photos
New Morel UW 958 woofer 8" Lindell Multi-Way 1 24th March 2009 10:57 PM
new woofer from morel Audist Multi-Way 4 11th October 2008 09:48 PM
Morel woofer? Audist Multi-Way 0 10th July 2008 12:38 AM
Morel 8in Woofer (MW265) and Top Mount Tweeter (MDT41) mmgando Swap Meet 2 13th December 2007 05:16 PM
MW vs. H series morel woofer ermes Multi-Way 11 24th January 2005 07:48 AM
Page generated in 0.08501 seconds (72.12% PHP - 27.88% MySQL) with 11 queries
