Old 16th September 2004, 01:10 PM   #1
foo is offline foo  Tibet
Default Scan midrange driver
I wanna use it as a mid-bass.
And active x.o at 200hz or below .(so the fs should be at least below 50 )
so i need a good mid-bass with low fs .
moreover,i still mant a high HPF xo point .(above 3khz)
Is the SS 15m/4531k suitable ?
How does it sound ?
Anymore better choices for this application ?
Old 16th September 2004, 02:31 PM   #2
Taco is offline Taco  Netherlands
ScanSpeak is a very good choice. If you want a more neutral driver you can consider Audio Technology C-quenze 15J. www.flexunits.com But the Scan has my preference.
Old 17th September 2004, 09:01 AM   #3
Geenius is offline Geenius  Netherlands
Geenius's Avatar
I have used the 12M4631G00 as a full-range driver (no crossover at either end, no other drivers envolved) and was pleasantly suprised by the result. Of course it misses top-end sparkle and low-end pressure but in between it was very clear and, considering no crossover was used, relativly neutral.
Tony
L-pad attenuator for midrange driver 6 1/4 inch driver rhythmdiy Multi-Way 0 4th November 2007 03:32 PM
best hi-end midrange driver joz Multi-Way 48 31st October 2007 01:20 PM
Scan Speak Midrange Ardee Multi-Way 1 13th July 2006 09:23 PM
Which driver for the midrange B4 Multi-Way 5 11th November 2005 10:07 PM
FS: Scan Speak Revelator 4.5" 12M/4631G midrange smokin rsx-s Swap Meet 0 23rd March 2005 06:47 PM
Page generated in 0.07948 seconds (69.49% PHP - 30.51% MySQL) with 10 queries
