More info than this is needed to give any kind of intellegent response... are you looking to make a rear-loaded horn for a fullrange driver, or are you trying to build a bass horn with the 8"er? What is the driver you have?
Joe
horn link
horn link#2
Joe
horn link
horn link#2
How patient are you?
Bill Fitzmaurice who posts here does amazing folded horns. On his site you can see the Tuba 24 - a 24" cube sub designed for PA use. He'll be publishing the Tuba 18 in AudioXPress in a couple months. It'll be an 18" cube designed for corner placement and tailored more for home use. It uses a cheap MCM 8", so even if it doesn't work with your current driver it's only $35 or so for the proper one.
I'm looking forward to seeing the plans, and am seriously considering trying one or two depending on the complexity.
http://www.billfitzmaurice.com/
- building a folding horn for the time
