Old 15th September 2004, 02:24 PM   #1
Question Video Shielding Question?
Is it necessary to use shielded drivers if you are using a DLP TV?
I am trying to help a friend build a home theater system for his house. He is wanting to stay under $600.00 for all speakers including sub.
I was looking at the Dayton home theater setup on speakerbuilder.net, but I know he would like a little more bass up front. If the tv doesn't need shielded speakers I will probably build three of the Dayton budget 2-ways on his site for the front and 2 of the HT speakers for the rear.
If it does need shielded speakers, could anyone recommend a good 2-way design that will still play relitively deep while keeping the cost down?
Thanks,
Ross
Old 15th September 2004, 04:13 PM   #2
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
I don't know what a DLP TV is, but the only display that requires shielded drivers is the traditional cathode ray tube - and this is because it uses magnetic deflection, so external magnetism means that electrons land in the wrong places, giving purity errors.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 15th September 2004, 07:09 PM   #3
cheesehead's Avatar
Default DLP
As I understand DLP, it's a light projector system that uses a chip with multiple small mirrors to generate the image. So you shouldn't need magnetic shielding.
There's a link here.
mk
DIY Video Shielding: Can It be Done Drumolator Full Range 2 15th February 2008 11:47 PM
Video Shielding Preacher Multi-Way 4 10th August 2006 03:04 AM
Steel DAC chassis Shielding Question fastcat95 Digital Source 1 2nd January 2005 06:36 AM
Page generated in 0.09244 seconds (61.65% PHP - 38.35% MySQL) with 10 queries
