I'm building an Orion-based surround system, with two full Orions for the mains, and 3 Orion upper baffles (T & M only) for the surround channels.
I would like to build the 5 Orion crossover boards inside one enclosure and one power supply, if possible. I have a few questions: 1) Can I put all 5 Orions ASP boards in one enclosure without any heat build-up problems? 2) Does anyone know the maximum expected +12 V & -12 V current draws for a single Orion ASP board (Or more importantly - a single power supply that can comfortably power all 5 boards)? 3) Any suggestions for an enclosure that would easily hold all the boards?
¿GotJazz? |
#2 |
(JPK) Not an answer to your question, but I can see you are going to have rather a lot of amplifiers to pull this off. So I though I'd throw this out before you get too far into your project. Have you considered my NaO design? The Mid/tweeter panel uses a passive crossover which would mean you would need only 7 channels of amplification total for 5 panels and two woofer system. The active circuits are much simpler too. Just a thought.
http://www.geocities.com/kreskovs/NaO.html
John k.... Music and Design NaO Dipole Loudspeakers. |
#3 | |
1) Don't see why not, it is not like they are class A amps 2) I can check this for you as I have built a board, I will try and post tomorrow. Otherwise check the opamp datasheet and multiply by the number of opamps 3) No idea, finding a cheap and nice enclosure is a big challenge. Try Teko, their Dissipator line is OK www.teko.com or www.elfa.se have some nice enclosures |
#4 |
Gotjazz,
You can assume about 9mA for each OPA2134 (if you use those) so multiply by the number of devices and you'll be pretty close. There's eleven op-amps on each board...times five...gives you about 500mA total. You should be conservative and find a power supply that will source probably double that. This sounds like an elaborate project. I'm not sure I would go that route, but I'm here to help if you need assistance assembling/testing the boards. Cheers, Davey. |
| Orion 222 SX repair questions | grjr | Car Audio | 11 | 22nd December 2007 07:32 AM |
| Orion crossover question | PT914 | Multi-Way | 1 | 18th December 2004 06:18 PM |
| Was building Phoenix ... Now maybe Orion? | ¿GotJazz? | Multi-Way | 56 | 15th November 2004 01:14 AM |
| Orion Construction Questions | ¿GotJazz? | Multi-Way | 3 | 6th October 2004 04:44 PM |
| Orion questions | dayneger | Multi-Way | 8 | 4th March 2004 09:28 PM |
| Page generated in 0.10048 seconds (68.70% PHP - 31.30% MySQL) with 10 queries |
