Vifa PL11 in small floorstanding
Old 14th September 2004, 08:12 AM   #1
Hilko Peter is offline Hilko Peter  Sweden
Default Vifa PL11 in small floorstanding
Hello group,
I’m considering designing a ”semi low-budget” small floor standing loudspeaker (aprox. 90x16x20 cm (hxwxd)) for in my office. So work will be a little more enjoyable
The units I'm considering to use are:
Bass/mid: Vifa PL11WG09-08
Tweeter: Vifa XT25TG 30-04
Internal volume around 7 liters, port 4.5 cm length 7-12 cm and crossover at 3kHz
Is there anybody who has worked with one or more of these units, or has any experience with the combination?
Any suggestions about other speakers of the same size are welcome as well.
Thanks!
Old 14th September 2004, 05:50 PM   #2
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
If you have the space for a floorstander I would use something larger than a PL11. There is a design using the PL14 and the XT25 on www.audiocomponents.nl which might be worth checking out. You should be able to use the same enclosure dimensions .
/U.
Old 15th September 2004, 10:55 AM   #3
I considered using this design of the Vifa Premium 11 and just redesigning the cabinet, but then I thought: why not try with an even smaller woofer. I don’t need that much bass at work (colleagues wouldn’t appreciate it I guess). So that’s why I considering to use the PL11
Old 15th September 2004, 11:24 AM   #4
Leonrocksnrolz is offline Leonrocksnrolz  Australia
I have used the larger PL18 drivers in a design with good success.
The PL11, if you only use one, will only require a very small box as you mention of 7 litres. Is there any reason for using a floorstanding design? Also, if bass isn't a large concern, perhaps a sealed system using a small morel driver or similar may be worth a look.
Old 15th September 2004, 12:31 PM   #5
The reason for a floorstanding design is that I skip making stands as well. The botom part of the speaker I will fill up sand so the speaker will stand a litle more stable.
I do not have a design ready yet, I have just been thinking a litle.
We probably all have those moments that we think: wouldn't it be cool to ...... and then you search a litle on the web and start up lspcad and trying some things and then you get a litle more excited. And well, that's where I am now.
Vifa PL11 in small floorstandingHide this!Advertise here!
Thiele Small for Vifa C20WH-07-08 ShanaVar Multi-Way 0 3rd March 2007 06:25 PM
poormans floorstanding tv\ht speakers req Multi-Way 3 6th December 2005 06:37 AM
FE108EZ or VIfa PL11-MG09-08 sachi Multi-Way 3 15th November 2005 10:00 AM
Vifa Floorstanding Speakers Big Kev ! Multi-Way 18 28th May 2005 02:33 AM
Peerless HDS MTM Floorstanding design. tktran Multi-Way 0 16th August 2004 12:13 AM
Copyright ©1999-2017 diyAudio
