Question for the Martin King crowd: what design goals drives the preference for long lines? The reason I ask is that for the two drivers I have for MLTL projects - pairs of TB W4-657s' and a Jordan JX92s' - the Mathcad sims always point to a short line as the best balance of LF excursion control, port 'junk' reduction and low pass band ripple. By short I mean 22" with a 3" L x 1.5" D port for the TB's, which results in bass more impressive anything that size has a right to push. The sim's in the .rtf attached. Short lines also push the 10th (?) harmonic port emmissions into a range which is easily attenuated with wall damping without affecting the primary port resonance. The Jordans look like they'll fall in the same range.
Yet people seem to prefer long, tapered line projects. Am I missing something obvious? |
#2 |
Ack! RTF's not allowed. Here it is in zip:
#3 | |||
To force a driver to a ~max flat response below what the driver's specs indicates, with the side benefit of being able to use an even shorter vent. Quote:
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#4 | |
GM
#5 | |
Did you measure different? |
#6 | |
Short vents are also at a disadvantage when considering port harmonics, long ones attenuate them better. So I'm just wondering if shorter lines are "tweakier" or something and why they're generally avoided. |
#7 | |
Of course once the stuffing is fine tuned in-room, odds are they will sound fine whether they are 'optimum' or not. GM
| long or short ribbon for 4khz+? | thadman | Multi-Way | 0 | 16th June 2007 08:16 PM |
| long-thin vs fat-short TL | Henkjan | Full Range | 26 | 22nd October 2006 07:54 PM |
| Long excursion vs short | Hayden | Car Audio | 19 | 5th March 2006 07:47 AM |
| Long and Short Power Cables | chris ma | Everything Else | 1 | 22nd September 2003 03:10 AM |
| Page generated in 0.12197 seconds (70.71% PHP - 29.29% MySQL) with 11 queries |
