Old 12th September 2004, 06:03 AM   #1
polsol is offline polsol  South Africa
Default How small can you go with a TL?
I would like to consider building TL lodspeakers for rear speakers in a suround sound application but do not want them to be obtrussive. If one looks at some of the all-in packages the rear speakers are small but not very good.
How slender can one go in a TL rear speaker arrangement with a single fullrange driver? Obviously the power handling of the drive unit may be problematic (assuming an amp of 50 to 75W) but I'm not sure how high the power handling of a small full range driver will go.
Any links to projects of this type would be appreciated.
Tony M
Old 12th September 2004, 01:38 PM   #2
Banned
Go to the Madisound site; there you can look at both Fostex full range drivers and cabinets designed to work with them.
Old 12th September 2004, 01:54 PM   #3
Send a message via MSN to blank527
Here is a quick search:
Picolino
Don't expect much from it..
Remco Blankesteijn
Old 12th September 2004, 03:24 PM   #4
paulspencer's Avatar
Here's a nice little surround TL by Keith Kidder:
Sentinel surround
It's basically a slim tower which you can place right near your listening position - no hassles with how to mount them on the wall etc.
I'm not sure you gain much with TL in this application though, if anything at all. If it is to be of an acceptable size, then you won't get much real bass.
Here's an alternative approach - it lets you use small drivers in a small box and maximise power handling and output. I think this is what you want in HT surrounds - small but dynamic with extension to 80 Hz.
Description of the little known QB5 loudspeaker alignment.
AUDIO BLOG | Bass integration guide
My work: www.redspade.com.au web design studio
small-signal (small-power) fast switching complementary transistors Lola Luna Solid State 3 8th April 2010 07:51 PM
Small-signal (or small power) pentode that can handle 400V (or more)? GordonW Tubes / Valves 12 13th June 2008 02:07 AM
PC-speakers + small amp (key words: small, cheap) rho Multi-Way 8 18th May 2006 01:19 PM
Small case for small boards pcspinheiro Class D 11 4th November 2005 05:20 AM
Page generated in 0.21830 seconds (29.67% PHP - 70.33% MySQL) with 10 queries
