Old 11th September 2004, 08:18 AM   #1
steverb is offline steverb  New Zealand
Default which measuremet software??
Ive just bought a measurement mic.
What software would be recommended to measure freq response of my speakers??
The DIY bug. Nothing is ever finished.
Old 11th September 2004, 09:00 AM   #2
I use Sample Champion http://purebits.com
Also because I am the author of it
Anyway, with this or other software, I suggest you also to use a very good soundcard for the measurements. Note that many modern soundcards work internally always at the same sample frequency (usually 48 kHz) and make a software resample of the other. This procedure for music listening *could* be acceptable but for audio measurements is not recommended and causes bad measurements.
Just try doing an impulse response loopback measurement with your soundcard to have the impulse response of the A/D and D/A stages (combined). You'll discover a lot of things about your soundcard.
Old 11th September 2004, 11:04 AM   #3
SY's Avatar
If you do a search, you'll find LOTS of discussion here about the merits/demerits of quite a few software packages. I haven't tried Sample Champion yet, but one very popular package is Speaker Workshop.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 12th September 2004, 03:47 AM   #4
If you have more time than money, try Speaker Workshop before anything else (because it's free).
Old 13th September 2004, 02:47 AM   #5
can someone tellme an good MIC to use as measure my speakers?
is ok with an MIC + SB audigy?
Old 13th September 2004, 02:48 PM   #6
osundoy is offline osundoy  Norway
Thumbs up Measurement Software
My personal favorite software are: www.winmls.com winmls2004 and DPA 4006 mic.... used on ESI Quatafire610 firewire soundcard
Old 13th September 2004, 02:53 PM   #7
AUDIX TR-40 combined with a standard mic pre with phantom power and some measurement software like sia smaart or winmls2004 are not too expensive...
Old 13th September 2004, 06:43 PM   #8
and what abt this mic?
http://www.behringer.com/ECM8000/index.cfm?lang=SPN
someone teste it?
thanks
Old 13th September 2004, 07:03 PM   #9
claudio is offline claudio  Italy
claudio's Avatar
I use the ECM8000, excellent for its price!
Claudio
Old 13th September 2004, 07:07 PM   #10
someone teste it?
thanks
This mic are almost the same as AUDIX TR-40 ( might be a bit cheaper..) and I have compared it with B&K (DPA ) 4006 and earthworx M30.
The behringer are a bit more noisy but will work fine for standard loudspeaker measurements.
the best software for this is winmls2004
made in Norway
SPL Measurement software questions Goldenboy Multi-Way 1 7th February 2007 02:01 AM
ARTA Measurement Software hongrn Multi-Way 1 2nd July 2006 07:46 AM
Preferred speaker measurement software? RHosch Multi-Way 6 31st May 2006 06:33 PM
speaker measurement software ucla88 Multi-Way 22 23rd February 2005 04:54 PM
Page generated in 0.10140 seconds (76.07% PHP - 23.93% MySQL) with 10 queries
