I have done some searching and don't seem to come up with a whole lot of people that have used Skaaning's AT drivers.
Can anyone who does have experience with these please comment on how they rate on the overall scale of being some of the best around. I am looking at using a midrange driver which will be in a sealed enclosure. I have used seas excel drivers in the past but would like to know how these stack up in detail and imaging qualities. Thanks for any comments that can be made, goskers |
#2 |
You also found Lama's comment in this thread
ACCUTON (THIEL) or ETON
Is that all there is? |
#3 |
Thanks for the link,
I believe that I read this at one point in time but not while I was looking at the AT gear. I am looking at using the c-quence 15H as a mid because that is what Per Skaaning recommended to me. He thinks the cquence is better and cheaper for this mid application because of the new cone. I think I will take this to heart and run with it as you rarely see a manufactorer recommend a cheaper model. Any comments regarding the AT for mid only apps? Cheers |
#4 |
Maybe you could contact this guy, selling AT drivers: FS: Skanning (Audio Technology) Woofers
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#5 |
I haven't heard it so far, so I can't comment on it, but the latest Sonus Faber uses a 15cm AT midrange driver.
I by myself use custom-built 8" AT woofers together with my Mangers. I am very happy with their sound and build-quality. Regards Charles |
#6 |
Here is a link with a loudspeaker being built with
CQuenze 15H520613SDK along with Scanspeak 26W8861T00, Scanspeak 18W8531G00, Morel Supreme 110: http://www.gattiweb.com/delta_construction.html |
#7 |
I've to make some remarks:
The cquenze 15H is a fine driver, the sound is very dynamic, but sometimes it seems to sound less open then the 18H. Or to put it differently the 18H sounds more laid back less compressed then the 15H. The level of microdetail is the same, but it sounds more natural with the 18H. I've contacted Per Skaaning about this, it seems that the sound signature of the 15H is due to the high acceleration factor (which is far higher then any other conventional cone drivers). For ppl like me who are looking for a more 'airy' and more laid back sound you have to consider (according to Per) the 15J (I've to look up the exact designation of this driver) with a smaller magnet and therefore a lower BL and a lower Rms due to the smaller physical dimensions of the magnet system. It sound resembles more on the 18H. |
#8 |
Thanks for the comments,
So, how does the AT c-quence line do when it comes to micro-detail retrieval? Is it on par with some of the best mag/ceramic hard cones? |
#9 | |||
Account Disabled
Troels Gravesen, http://home1.stofanet.dk/troels.gravesen/
went searching for a midrange driver for dipole operation from 300Hz-3Khz and along his journey tried a handful of drivers, including various 4", 5", 6/7". He tested the 18H52 1706 C-Quenze was bettered by the ScanSpeak 8545: Quote:
#10 | |
The micro detail retrieval is not the same as mag/ceramic. But the presentation of the details is very fluid/natural. With magnesium/ ceramic the details are all there, but the sound of those details are in some cases not real. It is hard to explain, I don't have the "being there" feeling with mag/ceramic. But I am a Scan Speak/ Audiotechnology fan |
| 8 Audio Technology C-Quenze drivers for sale | KBK | Swap Meet | 42 | 3rd March 2010 06:09 AM |
| MJ Audio Technology Magazine | sdivers | Swap Meet | 4 | 26th February 2009 07:20 AM |
| who knows LCY ribbon? LCY+Audio Technology? | iboxyl | Multi-Way | 1 | 15th March 2007 11:56 AM |
| Page generated in 0.14259 seconds (67.48% PHP - 32.52% MySQL) with 11 queries |
