I just completed the veneering of my Proac 2.5 clones with birch. The next step is to apply varnish. I must admit, I am pretty far from being an expert in paint jobs hence this thread. I would like to know: what type of varnish is best suitable for speakers (brand, finish, etc), what type of paint brush to use, is air brush recommended, special techniques for varnish application.
I am fairly proud of the result so far and I need help to keep the pride at the same level after the varnishing phase. |
#2 |
I have tried a number of other finishing products with varying levels of success but for my money, Watco danish oil is great. I typically use oak and follow a fairly intense process, described at steves shop'o'sawdust but, be warned, you need to do a lot of sanding! No special tools required, just some rags and waterproof sandpaper. If you do it right, it gives amazing results.
One thing you should be aware of is that birch can finish up with some "blotchiness". For this reason you might want to select a natural finish rather than one of the darker tones. I definitely don't recommend varnish. If you want a shiny surface, use wax. /Dave |
#3 |
If you don't care about the grain showing, you won't need to wet-sand each coat of Danish Oil on. Simply sand in between dry coats and wipe around 3 - 4 coats on and you'll have a stunning finish.
James |
#4 |
I agree with Watco or Waterlox, with multiple coats, lightly sanded with 320 grit paper and tacked between each coat. Simple buffed pastewax also makes a wonderful finish.
----------------------------------------------- Kilowattski |
| Focal Car Seps - Cabinet Suggestions | weng | Multi-Way | 9 | 9th August 2008 04:16 PM |
| isophon PH2132E - cabinet suggestions? | MichaelPublic | Multi-Way | 0 | 18th December 2006 02:47 AM |
| Suggestions for Speaker Varnish / Coatings | jkesa | Multi-Way | 17 | 5th June 2004 10:15 AM |
| cabinet suggestions for dual 15" jbl woofers | djquick_silver | Multi-Way | 4 | 24th September 2002 06:56 AM |
| Suggestions on stiffening woofer cabinet? | Keith TDI | Multi-Way | 4 | 17th March 2002 06:33 PM |
| Page generated in 0.09646 seconds (57.81% PHP - 42.19% MySQL) with 10 queries |
