Old 7th September 2004, 01:09 AM   #1
Default Enclosure volume allowances
I am no totally sure, but am I correct in assuming that if a speaker was to require an internal vented box volume of 0.75cu.ft, that I should add extra volume for the displacement of the speaker, plus the port, plus any bracing material, plus a factor allowance for damping materials used to the 0.75cu.ft?
Also if the above is the case, I am not sure as to how much should be added for the damping material. If I was to use one inch thick 85% - 100% wool lining on the enclosure walls what percentage should be added. I can easily work out the volume of the material but it is comprised of air and wool and but am not sure how much to add. It mentions on the PE site that 10% - 25% can be added. If you could please offer me some guidance as to how to allow for damping materials for a vented box volume and how much damping material to use that would be great.
Old 7th September 2004, 05:50 AM   #2
Send a message via AIM to johninCR Send a message via MSN to johninCR Send a message via Yahoo to johninCR
Yes the driver, bracing, and ports decrease the volume in computing Vb. Damping like wool and fiberfill do not.
Everyone has a photographic memory. It's just that most are out of film.
Old 7th September 2004, 01:02 PM   #3
Paradise_Ice's Avatar
You cant just say 10% air space for the drive unit, its not accurate at all, i have subwoofers that remove 8 litres of air with just the magnet assemble, you would be best to measure your drive units air displacement with a good air tight bag and a big bucket of water
Old 8th September 2004, 12:03 AM   #4
Talking Thanks
Thanks for your help!!!!!
Old 8th September 2004, 01:24 AM   #5
mltaunt is offline mltaunt  United States
Default diver volume
It would be nice if speaker manufacturers would supply this info. I would assume they all have 3D cad models that would make this a piece of cake. Maybe the big resellers like PE could talk them into supplying this data.
Old 8th September 2004, 12:16 PM   #6
Your right! i never though about that really,
Its simple to measure the volume when you have the drive unit in modular form.
Nice one Guys
Old 8th September 2004, 09:28 PM   #7
Ron E is offline Ron E  United States
Ron E's Avatar
Or you could guesstimate:
Take the measured diameter of the cone or the mounting diameter - call it D
Take the depth of the system from the back of the mounting frame to the back of the magnet - call it d
Approximate displacement volume is V = 0.25 * 0.33 * pi * D^2 * d This is the formula for a cone with base diameter D and height d. You can visualise this as a cone with diameter D with the point at the back of the magnet structure. The cone is taller than the actual driver cone, and the extra volume compensates for the volume of the magnet system.
For a Shiva, which has a diameter of 10 inches and a depth of 5.125 inches, you get 0.25*0.33*pi*100*5.125 = 133 cubic inches
Using mounting hole diameter (11 inches) for D, you get:
0.25*0.33*pi*121*5.125 = 161 cubic inches
Advertised displacement is 183 cubic inches.
As you can see, this gets you quite close without dunking your driver in water. I don't think your box design will be altered much by about 20-50 cubic inches......
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 9th September 2004, 07:32 AM   #8
rnoble is offline rnoble  Australia
Nice one Guys
If you are lucky enough they will have that fixed foam padding in the box for transport. I just used the imprint of the padding to test litreage, beats worring about waterproofing your driver.
Mltaunt they did with my tempest sub driver. I guess this is because the displacement is so large so I agree it should come with all driver TS paremeters!
Old 9th September 2004, 09:38 AM   #9
Mark25 is offline Mark25  United Kingdom
Mark25's Avatar
the area that a drive unit consumes from within an enclosure depends upon the thickness of your front baffle.
EDIT: and whether or not you rebate the mounting flange. (prob why manufacturers don't supply the data)
We will pay the price, but we will not count the cost...
Enclosure volume for HiVi B3S sploo Multi-Way 2 3rd April 2007 01:14 PM
Enclosure Volume Mat_89 Subwoofers 3 19th September 2006 10:27 AM
Enclosure Volume sonu Multi-Way 12 14th May 2004 09:38 AM
Sub: Volume of Enclosure with Amp bigkid Multi-Way 16 19th July 2003 06:12 AM
Enclosure Volume r_s_dhar Multi-Way 16 13th August 2002 06:24 AM
Page generated in 0.10292 seconds (75.27% PHP - 24.73% MySQL) with 10 queries
