Old 6th September 2004, 10:15 PM   #1
Josephjcole's Avatar
Default Baffle step question in wide-range 2way
So here is my plan. I've got a pair of the fostex 108e sigmas. Which I'm going to put in sealed ceramic enclosures. This should take me down to the 150-200 hz range. Then something to fill in the bottom end. The baffle on the fostex ceramic enclosure will be something like 6-8" (don't have them made quite yet).
Here is the first question: should I make the sealed enclosure small enough to get a small rise out of the fostex? I think, if my memory is correct, that with something like a .7 litter enclosure I could get a slight rise up to 200hz which would be up like 3db, falling from there. Would this help comensate for the small baffle?
Second question: The fostex is around 90db effecient, to correct for baffle step should I look for a woofer of around 93-94db effeciency?
Any input would be appriciated....
Also any suggestions on cheap (under $80 ) good woofers that would fit the bill would be appriciated
Joe
Old 7th September 2004, 07:46 PM   #2
Or could I just go "psuedo baffleless"... ie the baffle not more than a 1/2" wider than the actual driver itself, with a round over that started almost immediatly following the drivers edge. Then go for a bottom end that matches the 90Db fostex? This would certainly allow for a bigger selection of drivers, and allow for a lower QTC, letting the fostex cover slightly more of the lower end, and keeping the woofer out of more of the midrange.
Any thoughts?
Joe
Old 8th September 2004, 05:47 AM   #3
navin is offline navin  India
navin's Avatar
Send a message via MSN to navin Send a message via Yahoo to navin
baffle step is relared to baffle width and the smaller the width the higher the freq at which baffle step starts. over what range do you want to use the 108? the larger the range the less the max SPLs u will get.
let your SPL needs dictate the XO freq. and the XO freq. dictate baffle width. in any case a more sens woofer 92-93 db would be most certainly preferred. I'd look at the SEAS H333 or H372 or maybe even 2 x H397.
...still looking for the holy grail.
Old 8th September 2004, 01:35 PM   #4
I'm not so worried about maximum SPL's. I listen to the 108 in a backloaded horn right now and am happy with the volume I'm able to achieve. What I'm looking for is more extension on the bottom end and slightly cleaner mid-bass. I'll look into the SEAS drivers....
Joe
Wide dispersion speakers using full (wide) range drivers ozziozzi Full Range 1 28th December 2008 06:13 AM
F200A as wide range / XO Question LageB Full Range 0 12th November 2006 06:18 AM
Baffle Step question mazeroth Multi-Way 12 24th January 2006 10:45 PM
Overlapping driver freq range for Baffle step - problems? dvdwmth Multi-Way 6 15th November 2004 10:36 PM
baffle step basic question kneadle Multi-Way 11 18th July 2004 09:50 PM
Page generated in 0.09822 seconds (71.76% PHP - 28.24% MySQL) with 10 queries
