#1 | |
... a diaphragm enters breakup?
http://www.linkwitzlab.com/x-mid_dist.htm Quote:
#2 |
The quote is correct, but it's a different mechanism to breakup. What the quote describes is that the limited speed of sound in air means that, off-axis, sound radiating from opposite sides of the cone will no longer be in phase as the wavelength approaches the size of the cone. This means that a driver will start to become directional at higher frequencies, instead of radiating spherically.
On the other hand, breakup of a cone occurs near various resonant modes of the cone. The result is a very peaky frequency response at those frequencies. It depends on the geometry and material of the cone, and is not something that a DIYer would be able to calculate.
https://mrevil.asvachin.eu/ |
#3 |
Going back to GA Briggs in the 50's, it does seem that in general you can expect a first severe break-up from an 8" paper cone driver at around 3.5 to 4 KHz.
There's no doubt whatsoever that geometry and material properties play a huge role, but driving a cone from the center with a compliant edge mount does tend to limit the range of possibilities. |
#4 |
I think many people could be quite surprised at how low the break-up frequencies can be. In the picture of Vifa's measurement of their TC14WG49-08 speaker which is only 5.5 inches, I'd estimate the first severe break-up mode to be at about 1.1kHz-1.3kHz. The glitch may be next-to invisible considering the flatness of the frequency response, and there are only 2 small clues that suggest cone break-up:
1) A very small change in frequency causes a relatively large ripple in the amplitude response - ie: a high-Q notch or bandpass filter. 2) There is a small peak in the impedance plot caused by a sudden change in the effective mass of the cone. |
| Determine crossover frequency of existing XO | focal7C | Parts | 1 | 26th May 2008 09:07 AM |
| How to determine crossover frequency? | maurycy | Multi-Way | 2 | 7th January 2006 03:29 PM |
| How do I determine what this Transformer is? | wotan2525 | Solid State | 5 | 21st March 2003 05:34 PM |
| how to determine the pin layout of NPN or PnP? | tone | Solid State | 3 | 31st December 2002 01:15 PM |
| how do manufacturers determine frequency response? | pkgum | Multi-Way | 19 | 27th December 2001 05:08 PM |
| Page generated in 0.16228 seconds (36.85% PHP - 63.15% MySQL) with 11 queries |
