Old 4th September 2004, 01:25 PM   #1
Send a message via AIM to bhg41088 Send a message via MSN to bhg41088 Send a message via Yahoo to bhg41088
Default Audax Mini
John doesnt like people to email him and ask him these questions, so i brought it here. Can i replace the AP100Z0 with the AP130Z0 in his design without problems?
http://www.partsexpress.com/pdf/296-155.pdf
http://www.partsexpress.com/pdf/296-145.pdf
TIA.
Old 4th September 2004, 03:08 PM   #2
pinkmouse's Avatar
What is the Audax Mini? Any references?
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 4th September 2004, 03:15 PM   #3
wytco0 is offline wytco0  United Kingdom
Pinkmouse I think it refers to this http://home.new.rr.com/zaph/audio/audio-speaker14.html
Old 4th September 2004, 04:19 PM   #4
Yeah, thats the speaker. I thought i put a link to it in my post too. Any opinions?
Old 4th September 2004, 04:33 PM   #5
pinkmouse's Avatar
Ok, many of us in the UK have the AP100 in ongoing projects, and some also bought the AP130.
The drivers are not directly interchangeable, due to box volume issues, but if you search under the driver names there may be some suggestions that will help. I lost track of those threads a while ago as I was busy with work, but there may be some useful ideas there.
Al
Old 4th September 2004, 04:44 PM   #6
usekgb is offline usekgb  United States
usekgb's Avatar
I wouldn't replace the AP100 with the AP130. The AP100 just looks like a better driver, and John's x-over was designed for the AP100. Also, look at the waterfall plot of the AP130. It seems to have a pretty nasty resonance around 3k. This could cause some nastiness around the x-over frequencies and cause some extra sibilence.
Parts Express still has the AP100 in stock if you still need to get some.
Zach
Ahhhhhhhhh...............That's what that button does.
Old 4th September 2004, 05:20 PM   #7
Zaph is offline Zaph  United States
Zaph's Avatar
Default Re: Audax Mini
I used to get that question 10 times a day, and the answer is almost always no. I got tired of saying no all the time, it makes me feel all negative inside.
You hit it on the head. Crossing that driver over at or above 3khz would probably give it a harsh edge for some instruments, even if I was able to get a flat response out of it. The waterfall for the Mini is almost completely -25 db down at 1 ms for most of the range. (pretty good for cheap drivers) Additionally, the AP130 has quite a different response profile, efficiency, and wider baffle which affects the BSC.
In general, woofers almost never swap out. Tweeters are a little more forgiving for swapping into designs because of fewer differences in the low end rolloff. (not the TM025F1 however, that is one of a kind)
-Zaph|Audio-
the Very Mini Magico Mini zei Multi-Way 7 11th February 2008 08:10 PM
Audax Mini Speakers Lost-Again Introductions 3 30th May 2007 11:26 PM
Zaph's Audax Mini Crossover Question - Baffle Step 69stingray Multi-Way 1 6th January 2007 07:05 AM
Audax Mini Zaph meets up with MJK jackinnj Multi-Way 0 8th July 2006 02:00 AM
Page generated in 0.15569 seconds (55.69% PHP - 44.31% MySQL) with 10 queries
