Old 3rd September 2004, 09:29 PM   #1
Default poor mans measuring system...
hello. i don't have any "fancy" measuring equipment, and i wanted to measure some of the parts express 87cent speakers whilst trying some of the mods to see which ones work well...
is there an easy and simple way for me to do this? i have some boxes i but out a while ago that i could probobly use...
any ideas? i've never measured speakers before and this is mostly all new to me and i want to do this right
Old 3rd September 2004, 09:47 PM   #2
bzdang is offline bzdang  Canada
bzdang's Avatar
Not easy or simple, but it doesn't have to be too expensive. Cheapest route may be www.speakerworkshop.com plus a Behringer ecm800 mic and a compatible preamp (or the Apex clones), and a wallin jig-2. Not too expensive but it will hurt your brain.
Benford's law of controversy - Passion is inversely proportional to the amount of real information available.
Old 3rd September 2004, 10:06 PM   #3
johnnyx is offline johnnyx  United Kingdom
Praxis in demo mode (which is free) can measure the T/S parameters of your speakers, and measure their frequency response with RTA using a mic etc as in the above system. I find this easy to use, it sort of holds your hand as it leads you through the steps you need to perform the measurements. It won't hurt your brain quite so much, but it will still hurt. You will say, "but what does it all mean?" and be met with a deathly silence.
Look here
Old 3rd September 2004, 10:37 PM   #4
Default okay...
hmmm...
is there an easier way to JUST measure frequency response? or should i just go hog wild and measure everything...i really just wanted to see what the effects of the mods do to the speakers...
Old 3rd September 2004, 10:57 PM   #5
Sandy H.'s Avatar
If you are searching for changes to TS parameters, you could try Joe D's method from the Loudspeaker Design Cookbook. You could download SW to use your PC as a sine wave generator and a good DMM to measure the impedance characteristics. It will be an hour or two of writing down points, but for me, it was worth it to learn the what's and why's of the equations.
If you want frequency response, there would be more required. At least a mic/jig if you're lucky.
Sandy.
Old 3rd September 2004, 11:49 PM   #6
The RTA I described above will measure the frequency response of your mods. You just need a soundcard with a mic input. Use a condenser mic not moving-coil, (and definitely not a vocal mic)and the response will probably be good enough. Less hassle than a switch box and preamp.
Old 4th September 2004, 01:29 AM   #7
Default would this work...
hello...thanks for all you guys help...this forum rocks..
http://www.radioshack.com/product.as...5Fid=270%2D101
this is the mic i am looking at getting tonight...just so i can do some basic tests...
how do i go about setting this up? how far away should the mic be from the woofer? would it be good for me to guess 1 meter since most (all?) frequency responce graphs say 1m/1w?
i'm listening to one of these right now (the 80ish cent drivers from parts express) that are coated with dilluted elmers glue...it sounds pretty good...
thanks so much for helping a n00b like myself...
Old 4th September 2004, 01:04 PM   #8
My first measurements were made with something very similar. They need power, eg a battery, to bias the built-in FET. Tie-clip mics use a similar insert, but have a battery compartment to bias the FET, so it would be self-contained. Some soundcards, like my old Turtle Beach Fiji, have (jumper?) options to provide this bias, again leading to a self -contained unit. Check your soundcard specs.
Old 4th September 2004, 05:37 PM   #9
mgmopar is offline mgmopar  United States
mgmopar's Avatar
Hello,
I am too looking to make similar measurements. I was planing on using the out put of my sound level meter. Would this be fairly accurate, or should I too get a condenser microphone? (I am assuming that is what my meter uses.) I figured weighting C would give the full output range but I am not sure? If this is suitable it may save others from having to buy any additional equipment.
burning the candle at both ends makes for a waxy mess.
Old 4th September 2004, 06:25 PM   #10
Jimmy154's Avatar
Cheapest way is get panasonic capsole and get audiotester; total cost $5. Just search for my name and mic (or similar) and your should find a microphone thread started by alvaius I believe. If you find the thread you will see I used a 9V battery, a cap, and resistor, but if you use audiotester and mic input on your sound card you don't even need this setup. All you need is straw capsole soldered to wires that go straight to sound card.
I could never get SpeakerWorkshop to work, with the capsole.
poor mans strad as center skogs Multi-Way 6 28th September 2007 09:16 AM
Need recommendation for a PC-based measuring system andy2 Multi-Way 10 23rd December 2006 10:27 AM
measuring in-room response of speaker system cporada Multi-Way 0 1st November 2005 04:50 PM
Page generated in 0.11193 seconds (77.64% PHP - 22.36% MySQL) with 10 queries
