I only have the following parameters for the subwoofer
frequency range - 20Hz - 700Hz impedance 8-ohm max power 750W spl - 89dB Fs - 25Hz It is a 12" subwoofer made by audio X (one of those cheap brands) Which enclosure volume will be best for this subwoofer? |
#2 |
For home, try it in a 1.5 - 2.5 ft3 sealed box.
For auto, these cheapie subs generally work pretty well in a 1 - 1.5 ft3 sealed box. If this is an auto sub, it will probably not sound very good in your house due to a high Qts (which is unknown of course). I would not go ported since you have no way of optimizing it, and definately not bandpass for the same reason (and bandpass is a huge compromise with any sub). Good luck.
- Chris |
| SUB woofer enclosure size | sumovanner | Subwoofers | 3 | 4th December 2008 05:32 PM |
| Enclosure size question | Flyin11 | Car Audio | 15 | 19th November 2007 10:42 PM |
| F3 Vs. Enclosure Size Question | crippledchicken | Subwoofers | 0 | 12th December 2006 03:05 PM |
| Proper enclosure size? | Thepistolpete | Subwoofers | 4 | 14th December 2005 09:48 AM |
| enclosure size too big? | Wagener | Multi-Way | 5 | 2nd October 2004 01:32 AM |
| Page generated in 0.06061 seconds (76.59% PHP - 23.41% MySQL) with 10 queries |
