Multi-driver, horizontal center speaker with TB-871? - Page 3 - diyAudio
Old 16th October 2004, 05:15 AM   #21
thomas997's Avatar
I use two of the W4-657.
You could go for the W4-656 used in MarkMck's mods (and of course do his mods).
Old 17th October 2004, 07:47 PM   #22
acenovelty's Avatar
Originally posted by Timn8ter
Well, that's one down. How about having one speaker above and one below the picture? I think I tried that once but it's been a while. I think the WAF factor was about zero which is why I abandoned it rather quicky.
Hello Timn8ter,
Not having the Wife Factor you speak about, (mine always wants more, bigger, higher fidelity), I built horizontal center channel speakers for above and below the monitor over 10 years ago. They are driven by an old Lexicon CP-3. Monitor is 36" wide, center channel speakers fill that space above and below. Bottom center channel is at your ear level, top center speaker is aimed downward to your ear level. Use a piece of string. Self built cabinet for monitor/speakers was designed around this idea.
According to all the experts, this is heresy. Granted I'm not an electronics engineer or an acoustics engineer. The single vertical center channel I started with just did not sound right to my ears.
The sound stage for the center channel is about 12 feet wide in my little room and stays locked on the screen no matter where you sit.
Volume control on the Leach amp that drives them allows me to tinker with the final output.
I'm a happy camper.
Prosit
Old 18th October 2004, 06:01 PM   #23
morbo is offline morbo  Canada
Out of curiosity, has anyone actually built a bessel array center as described on this thread, that is an array of 5 drivers wired in the bessel arrangement? If so, can you tell us how far away you needed to be for the 'effect' to work?
Old 18th October 2004, 06:11 PM   #24
Timn8ter's Avatar
Originally posted by acenovelty
Hello Timn8ter,
The WAF came into play because we have a 65" rear projector so the lower speaker had to sit in front of the console. I'm glad to hear positive results and will keep that in mind when I trade up to the front projector. Thanks.
Old 18th October 2004, 06:29 PM   #25
Send a message via AIM to johninCR Send a message via MSN to johninCR Send a message via Yahoo to johninCR
When I was experimenting with bessels I played with the 5 and 7 unit arrays, but mostly the 7 because the middle space was 0 power and perfect for a tweeter. I dropped it because an array pair had zero imaging, just a wall of sound from between the speakers. I don't recall any big difference in SQ related to distance, but I didn't really do any nearfield critical listening.
The wiring posted earlier was just from memory. I was about 6 months ago and the link I had doesn't work any more. I'm certain there was 1 ea of the -2 and -1, but I'm not certain if the -1 was on the end or the driver next to the end.
The bessel "effect" is related to dispersion outside of the plane of the array and it does work even in the very near field.
The old link I had was to a copy of a page from Don & Carolyn Davis's book "Sound System Engineering" which included wiring configurations for a number of different bessel arrays, so if anyone has this book, please post a copy of that page.
Everyone has a photographic memory. It's just that most are out of film.
Old 18th October 2004, 06:47 PM   #26
frugal-phile(tm)
planet10's Avatar
This book has a very good description and formulas for deriving any size array. Attached are an extract from the above that describes 5 & 7 (really 6) driver arrarys.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 18th October 2004, 06:51 PM   #27
Thats interesting... I have read in several places from fairly well respected people that the Bessell array only sounds like a point source from a great distance away. The only quote I could find offhand is from the LDSG:
One final note: Sooner or later, many people's research into arrays leads them to Bessel arrays. A Bessel array is a specially wired vertical array whose apparent vertical size varies with frequency, thereby avoiding the ragged vertical polar response of a normal vertical array. This appears to be an attractive design. However, most references to Bessel arrays fail to mention that they're only effective at listening distances equal to, or greater than, approximately ten times the array length. This makes them unsuitable for most home application, although they're used to good effect in many stage and professional systems. For more information, a good source is the Meyer Sound web site.
However I have seen Jim Griffin and others mention this as well. I hope you're right, as it would be ideal for my application.
Old 18th October 2004, 06:55 PM   #28
Thanks Dave, this time I saved a copy.
Old 18th October 2004, 07:55 PM   #29
My testing was pretty crude. I was using vertical arrays and even at distances less than 1 meter the dispersion was totally different than with a normal array. With a normal array, the line of the plane is very clear and once above it the SPL reduction is very very significant. With the bessel, this clear line doesn't exist. I think this may be another case where the theory conflicts with the real world in small rooms and short arrays, because I find that issues of lobing, near field/far field transition, etc aren't very significant for in-home arrays.
Another alternative would be a normally wire array but on a convex baffle to give you good horizontal dispersion. That way you would also get the full sensitivity increase of multiple drivers. You may want to look at JBL's papers for J and Spiral arrays.
Old 18th October 2004, 08:06 PM   #30
You may want to look at JBL's papers are J and Spiral arrays.
Thanks for the reference, I'll have a look at these.
Horizontal MTM Center channel: avoiding off-axis nulls DcibeL Multi-Way 27 10th October 2009 06:57 PM
Vertical/Horizontal 2 x JXR6 Linear Array as central speaker ? fvaille Full Range 6 11th January 2009 11:20 PM
horizontal digital media center blue934 Parts 3 12th August 2008 03:54 PM
Horizontal speaker alignment - 2way, 2.5way fb Multi-Way 2 11th August 2008 10:12 PM
Multi driver TLs mashaffer Subwoofers 9 8th August 2006 02:21 AM
Copyright 1999-2017 diyAudio
