Old 29th August 2004, 04:31 AM   #1
Default series wiring
does wiring speakers in series put them out of phase?
im not worried about the massive current loss, just sound quality.
Old 29th August 2004, 04:38 AM   #2
Bill Fitzpatrick's Avatar
+ speaker - + speaker - is in phase
+ speaker - - speaker + is out of phase
Old 29th August 2004, 04:42 AM   #3
so series wiring wont affect sound quality (vs parrallel wiring that is)
Old 29th August 2004, 06:11 AM   #4
Yes and No.
Wiring two tweeters in series is a no-no because you will have 2 tweeters. It's standard practice to only have a single tweeter per channel - and for good reason.
Wiring two DIFFERENT speaker systems in series will cause each to sound different than they originally did.
Is there something specific you have in mind?
Old 29th August 2004, 06:15 AM   #5
i was thinking of two fostex fx200's (8") in series, or maybe two fe 206 e (6.5"), cos they have more top end.
....maybe even a mix of one each?
Old 29th August 2004, 06:38 AM   #6
For the same reason you shouldn't use 2 tweeters, 2 full range drivers should be avoided. The high frequency performance will be disappointing.
Old 29th August 2004, 06:52 AM   #7
dp you have any links to sites that explain series connection, cos it looks like theres alot to read up on.
your help is much appreciated
Old 29th August 2004, 07:12 AM   #8
Running two full ranges per channel is bad practice for acoustic reasons - series or parallel has nothing to do with it. Put the idea out of your mind. Why did you want a series connection anyway?
Old 29th August 2004, 07:29 AM   #9
i was thinking two speakers = louder sound, plus so many "hig-end" speakers have reviews bragging about how much better the sound is because of two drivers.
the only reason i was thinking about series connection, over parrallel, is because my amp will run hot and not as clear at 4ohm.
at the end of the day what i want is speakers that are as "realistic" as possible.
Old 29th August 2004, 07:53 AM   #10
There are often good reasons to double up on drivers but not if they are reproducing upper mids and highs.
What makes you think that your amp will be less than happy at 4 ohms? What kind of amp is it? What's your budget for speakers? Do you have the tools and skills to build proper enclosures?
Wiring series and then parallel with switch hemos Power Supplies 4 17th November 2008 01:34 AM
wiring smps in series morpheus82 Power Supplies 34 13th November 2006 06:50 PM
Series wiring (Qts) Query badgerboy Full Range 4 30th August 2006 11:52 AM
Series wiring for heaters XZur Tubes / Valves 5 19th December 2005 02:43 AM
Series Wiring Rory Multi-Way 10 10th September 2001 03:27 PM
Page generated in 0.10626 seconds (78.63% PHP - 21.37% MySQL) with 10 queries
