Old 28th August 2004, 07:48 AM   #1
polsol is offline polsol  South Africa
Default Capacitors in Cabinets
Have been thinking for a while about the advisability of putting capacitors into passive speaker boxes. As there are a lot of acoustical waves bouncing around in the cabinet, is it not possible that these could have an effect on distortion?
After all, capacitors are neither opaque or transparent to audio waves and there must be some transmission of the waves through the capacitors themselves which would, presumably, produce variations in the capacitance and modulate the signal.
Has this ever been investigated
Just a thought but comments would be appreciated.
Tony M
Old 28th August 2004, 08:24 AM   #2
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
Generally in the Fanatical Audiophile world people keep the crossover filters outside the box for this reason- also because you can then keep tweaking the values until you go insane..
Old 29th August 2004, 05:25 AM   #3
These internal vibrations also affect inductors, which is why I pot the ones I wind or use foil type chokes to minimize susceptibility. You can also make a subcompartment within the speaker cabinet to hold xover components.
what is the difference between silver mica capacitors and ceramic capacitors ?? prorms Solid State 1 6th May 2008 12:38 PM
Re-using cabinets? pbled Multi-Way 0 30th March 2005 09:22 AM
Continental Capacitors' "Type-A" oil-filled capacitors? radical Parts 0 21st October 2004 08:39 PM
capacitors: panasonic FC vs elna RJH vs rubycon ZA capacitors costiss Parts 11 30th January 2003 09:32 PM
differences between computer grade capacitors and small can capacitors LBHajdu Pass Labs 0 22nd February 2002 01:29 AM
Page generated in 0.07972 seconds (64.59% PHP - 35.41% MySQL) with 10 queries
