Speaker Selection?
Speaker Selection?
Old 13th June 2002, 03:53 PM   #31
Jeroth is offline Jeroth
Thanks for the huge amount of responses by everyone.I dont think I will be making a Sub Woofer in the future, and I will only be using a .25 cu ft enclosure if i order one off the net because the bigger ones r too expensive.
I WANT to build and cut my own cabinet because it will be cheeper, but how do you cut such perfect holes, and even more so, how do you cut them so the speakers can be flush mounted.
I dont have fancy tools, just the basics(drill etc).
I was thinking of buying the speakers and then going to Bunnings and telling them what sizes I need, and then getting THEM to cut the cabinets and also cut the holes for the speakers, could i do this.
Jeroth
Old 13th June 2002, 04:48 PM   #32
Default OK!
Thanks to the links that GlennME posted up 4 me, I have found a design that I would like to try out.It uses the exact speakers that I have decided on(The Vifa's)and also explains in detail how to do EVERYTHING.It also offers different construction tips so you can customize the look to the way u want it.They said that this has got an extremely good frequency response, and is also good quality.Well here is the link 4 u to go and have a look.If you can, read the whole thing and tell me what you think.
I personally think it is perfect for me, seeing as though this is my first project.
Jeroth
Old 13th June 2002, 10:53 PM   #33
griff is offline griff  Australia
griff's Avatar
You can't really go wrong with a kit, Good Luck, if you need any construction advice then give us a yell.
griff
Old 14th June 2002, 02:50 AM   #34
So what do u think of getting the pieces and holes cut at bunnings in the cut shop.
Old 14th June 2002, 03:02 AM   #35
GlennME is offline GlennME
I don't think Bunnings is set up for cutting holes. They'll probably cut the sheet of MDF for you, but you'll have to cut the holes yourself. There's bound to be someone you know, or a neighbour in your street, who has a Jigsaw. See if you can borrow one for a couple of hours.
Old 14th June 2002, 03:27 AM   #36
But then how do I get a perfect hole and also how do a flush mount the speakers.
Old 14th June 2002, 03:32 AM   #37
It'd be no problem for anyone with a router. Routers easily cut and recess holes. Better find someone with a router, or perhaps a carpenter or cabinet maker would do the work for you for a small fee.
Old 14th June 2002, 03:57 AM   #38
How much does a 2nd hand router cost and is it possible to hire one.
Old 14th June 2002, 04:13 AM   #39
Default Tweeter?
I have chosen
this project and people suggesed earlier that i shouldnt get tweeters with a alluminium dome because they can be a bit harsh, I have decided to do this and have found a replacement by Vifa that has the EXACT same specs excpet that the new one i have chosen has a slightly lower FS which would be better, and the old one can go up to 3500hz and the new one up to 30000hz.Here are the details:
Previous Decision:
VIFA D25ASG-05 1" SHIELDED ALUMINUM DOME TWEETER
New Decision:
VIFA D26SG-05 1" SHIELDED TEXTILE DOME TWEETER
Do u think this is a good replacement?
Jeroth
Old 14th June 2002, 06:27 AM   #40
griff's Avatar
thats a fine choice, keep in mind that some sort of crossover change may be necessary
griff
Speaker Selection?Hide this!Advertise here!
DIY: SI T Amp Boombox, FR Speaker Selection dellaseppes Full Range 35 20th February 2007 04:35 AM
seas speaker selection hero89cq Multi-Way 4 12th February 2007 07:51 AM
new on-wall speaker for selection denbo123 Multi-Way 0 3rd August 2006 02:30 PM
Speaker selection help lbreevesii Multi-Way 0 1st April 2006 03:14 PM
