#11 |
When i said AUD$200 for the speakers i meant for the tweeters also.And do u think you could post the URL's for any of those oz sites.Thanks!
Jeroth
#12 |
Warp Engineer
On Holiday
Ok just a little clarification, when you said AUD$200 for the speakers, i assumed that included the drivers, crossovers, enclosures etc ... in short the whole thing.... if this is not the case please let me know. I dont have the links with me right now but once we decide on particular drivers, i can chase up the relavant links for you.
#13 |
Here is the precise info:
I currently have AUD$200.00 in my account.I was planning on using this to purchase a pair of Woofers AND a pair of tweeters. Then, start saving more money up and buy the rest of the things like cabinets etc in about a month. If u think I would be able to get more than just the Woofers and Tweeters for this amount, PLEASE tell me. Remember that I dont want the best system in the world, just reasonable quality speakers for my room. Jeroth
#14 |
Well, this guy is in New York so it may be a problem, but I've had good experiences with http://www.zalytron.com
Under the budget speaker section, he has two kits that you might be interested in: the JML 5"TM ($99USD) and the German 2-Way ($110USD). The kits come with speaker drivers, crossover components and binding posts. Cabinets cost more, but you could save alot of money by building your own, particularly because of shipping cost, but I suppose you were planning on doing that anyway. -Won PS Welcome to the club |
#15 |
frugal-phile(tm)
1st on the power thing. Except possibly in the Pro world, power handling of a speaker is not a very useful parameter. You are more likely to break a speaker if you have too little power then too much -- clipping, particularily with SS, is the enemy. Since music tends to be quite dynamic if you keep the peaks below clipping, then the average power levels will be quite low. If we assume that peaks are 20 dB above the average, and you are pushing the amp to its limit, but not clipping then the average power would be about 6 W. You do have to keep in mind that the rated power is into an 8 ohm resistor and into a real loudspeaker it is likely the amp won't be able to deliver quite as much power.
Generally (it varies quite a bit by type of music) the point at which there is a 50/50 power distrubution is at 300 Hz. With a 2-way what is most commonly seen are systems with a 5 or 6" midbass and a dome tweeter with a cross-over between 2.5 and 5kHz. On these systems the woofer needs to handle the most power, but the tweeter is more likely to burn up if you run the amp into clipping. Andy G is in Oz and has built a number of speakers from parts available there. He is also very helpful. dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#16 |
What is clipping!?!
#17 |
Clipping... http://sound.westhost.com/amp-sound.htm a little ways down has a few paragraphs on "Clipping Distortion", that will explain it better then I can in a post...
#18 |
I Have been looking on the net and have narrowed a selection down, and have decided on Woofers & Tweeters.If these are the wrong things to get please tell me why(Wattage, Frequency Response etc).Remember that I have a 2 channel amp, with 120W RMS per/ch.Here is what I have chosen so far:
Woofer: VIFA P17WJ-00 6-1/2" 8 ohms Power handling: 70WRMS/100Wmax Frequency response: 37-5,000 Hz Fs: 37 Hz SPL: 88 dB 1W/1m Tweeter: 1" ALUMINUM DOME TWEETER 8 ohms Power handling: 70WRMS/100Wmax Frequency range: 2,500-20,000 Hz Fs: 1,530 Hz SPL: 92 dB 2.83V/1m Thats what i thought will be fine but if anyone thinks otherwise, please post what should be different, things such as Wattage, Frequency Response etc.If you think this will work with my amp please tell me. Jeroth
#19 | |
frugal-phile(tm)
dave
#20 |
Warp Engineer
On Holiday
Yes I agree spend more time looking for a tweeter.... I dont much like metal dome tweeters as they are often harsh and just a word of warning, tweeters are often rated for system power (ie. amp output power) not for their own input power make sure whatever tweeter you choose is capable of what you want in this respect. Low Fs helps by taking some of the strain off the woofer (woofers dont do a great job of producing treble) and also allows for a more simple crossover.
| DIY: SI T Amp Boombox, FR Speaker Selection | dellaseppes | Full Range | 35 | 20th February 2007 04:35 AM |
| seas speaker selection | hero89cq | Multi-Way | 4 | 12th February 2007 07:51 AM |
| new on-wall speaker for selection | denbo123 | Multi-Way | 0 | 3rd August 2006 02:30 PM |
| Speaker selection help | lbreevesii | Multi-Way | 0 | 1st April 2006 03:14 PM |
