Old 28th August 2004, 04:18 AM   #1
Default proper way to store drivers
is there a proper way to store driver .
I have a couple I want for a project down the track. [ 2peerless csx12']
As I live in the tropics humdity & heat is a problem .
I dont want them to deteriorate thanks
Old 28th August 2004, 05:24 AM   #2
HiSPL is offline HiSPL  United States
Send them to me...
I'll store them properly, and make sure they get "exercised" properly...
Hey, do you hear that?
Old 28th August 2004, 05:37 AM   #3
rcavictim's Avatar
For humidity protection you could seal them in doubled plastic bags and packing tape seal with dessicant dryer packages inside the bags. I don't know how much heat you are talking but I imagine some drivers can stand much more dry heat than others. Expect to be disappointed with drivers using foam surrounds or plastic cones I'd think. Come to think about it, you don't have to live in the tropics to be disappointed by such drivers.
Caveat: No intent was made to inflame the owners of good drivers with polypropelene cones. However, if you have foam surrounds, well that's your problem, fortunately not mine.
I.Q.Test. Have you ever purchased a recreational snowmobile?
Old 28th August 2004, 02:25 PM   #4
I am talking about 35+ c in summer . humidty 90% +
HiSPL it would be cheaper for you to buy your own . because I not going to pay the shipping to send mine to you
Old 28th August 2004, 08:17 PM   #5
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
I have heard that what attacks surounds are light and ozone
So if they were in black plastic bags I think you are covered on that
Well, displacing the air with nitrogen would help I'd think.
It seems that carbon dioxide is much more available though.
I've always wondered if CO2 would work since the oxygen is pretty tied up chemically I think. I don't know...
If you put them in a with dessicant and AWAY FROM LIGHT, you would be OK I think. Also packing the bag in a big box with a bunch of blankets/clothing around them would cut down on temp swings.
If you use a big bag, after a couple of days you could isolate the dessicant in an area near the mouth, and tie it off, remove it, and add a new batch of dessicant after the first batch had done its work, to make sure the dessicant is fresh and functional. Then I think you would be set for a couple of years or so....
Old 28th August 2004, 09:23 PM   #6
5th element's Avatar
Also remember to place the drive units in the same orientation they would be in in 99% of speakers, facing fowards etc. If they are stored as per a down firing application the weight of the cone and time can cause it all to sag, which is not what you want. I have my 10" csx stored in the XLS10 boxes on a shelf placed vertically.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 28th August 2004, 10:16 PM   #7
frugal-phile(tm)
planet10's Avatar
Yes, that trick works nicely.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 29th August 2004, 03:50 AM   #8
Zaph is offline Zaph  United States
Zaph's Avatar
When I get new drivers in, it seems they often have a bit of cone sag, and usually towards the magnet. Storing them face down sometimes corrects that problem.
The funny thing is, I have a Peerless sub in my closet right now, stored face down, with 30 coins taped to the back of the cone to undo a little cone sag. Last time I checked, it was just about perfect.
-Zaph|Audio-
1st order filters/crossovers with proper drivers compared to full range? tech.knockout Multi-Way 8 15th May 2006 06:52 AM
Looking for proper transformer. contaxchen Parts 0 15th September 2004 02:38 AM
An on-line store in Australia / New Zealand to order subwoofer drivers and amps? Dave Bullet Subwoofers 5 13th January 2002 06:12 AM
Page generated in 0.11430 seconds (71.53% PHP - 28.47% MySQL) with 10 queries
