#21 |
It seems not to have been mentioned so the techie bits.
It's the current through the windings that affects the saturation of the core. The flux density increases with current and eventually the ferrite core saturates. Some ferrite is specified for audio use, however you'll need to check whether or not it's suitable for the current that you'll be putting through the windings. What you're looking for are ferrites that have high values for H and B in the specifications. I can't tell you what values would be regarded as "high", perhaps someone else can. regards, Keith |
#22 |
If I were to settle down to winding air core coils, would the quality of the wire used make any difference? Specifically, can I use the enamelled wire generally used in winding transformers? Dont tell me that there are gold or silver plated ones!! I have used these transformer enamelled wires and have settled down to like the audio quality -- how could I be dissatisfied in the absence of any comparison?
please advise. |
#23 |
I've built quite a few inductors, and every time i used enamelled wire i saved up from different (dead) transformers. Works great for me!
#24 |
Great help. Thanks everyone.
#25 |
Just thought that I would throw in that they sell enamelled wire specifically for winding transformers and inductors. In Designing, Building and Testing Loudspeakers, author David Weems recommends old transformers as a source of wire. It is not some sort of thing you are "getting away with"-that is what the wire is for.
Remember, the thinner the wire, the cheaper, but also the greater DC resistance. Try to keep the DC resistance under 1 ohm, if possible. Otherwise, enjoy "rolling your own"!
#26 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
| Which, Foil Air Core or Iron Core Inductors | slhijb | Multi-Way | 16 | 20th November 2009 03:12 AM |
| inductor/choke/air core/ferrite core. . . same thing? | poolorpond | Pass Labs | 24 | 29th March 2008 10:55 PM |
| Solen Air core inductors, Hammond Iron core. | gnomus | Swap Meet | 0 | 30th July 2004 01:28 AM |
| broken ferrite core for smps | sss | Car Audio | 4 | 13th April 2004 01:30 AM |
| AIR-Core Vs Ferrite-Core Inductor in Class-D amplifiers | Workhorse | Solid State | 13 | 23rd January 2004 09:14 AM |
| Page generated in 0.11424 seconds (63.49% PHP - 36.51% MySQL) with 10 queries |
