Old 27th August 2004, 12:40 AM   #1
Default When reading a response graph...
From Parts Express, which line do you look at? The top or the bottom? I'm mainly looking at tweeters and their response graphs have 2 graphs. Not sure which one to look at or what their differences are?
Thanks!
Old 27th August 2004, 02:11 AM   #2
5th element's Avatar
Im not entirely sure what you are refering too. For instance if I look at the Tang Band 28-847SA tweeter. You have four files to look at. One is the specs the manufacture produce which are pretty self explanatory. And then there is the measurements PE have taken themselves I assume. These both contain impedance -the thre resistance of the voice coil changes with frequency. And frequency response, which is how the output SPL of the tweeter varies with frequency. Both of those are equaly important. Then there are the Clio export txt files, which can be used by ppl with simulating programs to get the PE measured Freq res and impedance of the driver into their program easily.
If you are asking which do you use, the manufactures or PE? I would say none, measure yourself. But failing that Id probably use the PE. Why? they are not a manufacture trying to smooth out a bumpy freq graph, they will tell is as it is more often then not.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 27th August 2004, 02:13 AM   #3
I just had a rethink, are you refering to the 0 degree and 30 degress off axis response of frequency response on the same graph? If so its up to you which one to choose. We rarely listen at 30 degress its more like 10 when sitting in a properly set up system. Either way its not that important. Although the off axis gives you a good indication of a woofers high frequency performance.
Old 27th August 2004, 09:10 PM   #4
Thanks 5th, that's what I needed to know. After hearing you say the 30 degrees off axis it clicked in my mind and now I remember reading that before. Thanks
Old 27th August 2004, 09:38 PM   #5
Banned
That 30 degree off axis response is far more important than on axis. For proper imaging it's recommended that the 30 degree response be no more than 6dB down from on axis, and that applies to all drivers, not just tweeters. This is how most designers decide on the crossover points.
Why does the BiB's frequency response graph go all spazzy, and why can't we hear it? Spasticteapot Full Range 6 7th November 2006 09:56 AM
How To Read Martin King's Step Response Graph? kelticwizard Multi-Way 10 3rd March 2006 12:41 AM
Vifa, extra lines in response curve graph? Layberinthius Multi-Way 3 31st March 2004 10:48 AM
frequency response graph acceptable? tech.knockout Multi-Way 15 28th June 2003 05:23 AM
response graph for scan speak ttvonau Multi-Way 12 4th June 2002 08:53 AM
Page generated in 0.07861 seconds (71.47% PHP - 28.53% MySQL) with 10 queries
