Old 25th August 2004, 02:33 PM   #1
Artmaster's Avatar
Send a message via ICQ to Artmaster Send a message via MSN to Artmaster
Default sand-glass port
hello!
I want to do sand-glass, or egg-glass port for my subwoofer.
it's should be round.
how can I make it? which material and method?
thank you
Artmaster live in www.artmaydan.org.ua
Old 25th August 2004, 03:23 PM   #2
saabie22's Avatar
Yury,
You could try using PVC pipe reducers like the one shown in this attachment.
I don't know if you will have a step inside the fitting where the straight tube is connected. You might be able to smooth this with a file.
I've seen these fittings with about a 2:1 ratio between the large and small diameters.
Your picture shows a narrow angle (30 degrees?). These fittings usually have a 90 degree cone angle.
Good luck!
Mike
Old 25th August 2004, 04:13 PM   #3
markp is offline markp  United States
That shape is called an 'hour-glass' in English. That might help you find it in a search.
If it sounds good... it is good!
Old 26th August 2004, 06:43 AM   #4
Artmaster's Avatar
thank you markp to put right my English. I couldn't write correctly yet. it's important for me. ok. I'll try
dear saabie22, I won't do my port by 90 degree cone angle. I wanna do it round. theoretically I wish to make it exponential.
thas I ask all of you about it
Old 26th August 2004, 07:16 AM   #5
Maybe you could turn it up on a lathe out of wood? Maybe do it in two pieces and join it in the middle?
Old 26th August 2004, 07:32 AM   #6
Artmaster's Avatar
it's will be nice , but I'm not a lathe operator.
now I think about gypsum
but it's difficult either, and not exactly what I want.
Old 26th August 2004, 08:17 AM   #7
zuki is offline zuki  United States
http://www.partsexpress.com/webpage....63528&desc=ASC
Old 26th August 2004, 08:42 AM   #8
Artmaster's Avatar
I couldn't see it.
my firewall close access to "sex" sites
something interesting for me? except girls, boys and other stimulator?
Old 26th August 2004, 06:50 PM   #9
bogoes is offline bogoes  United States
Send a message via AIM to bogoes
Here, try Madisond instead, they and PartsExpress sell flared ports. Scan about half way down the page to find the ports.
Madisound Accessories
Good luck.
- Chris
paint sand paint sand .... Madmike2 Multi-Way 44 15th June 2005 08:10 PM
lead vs sand IZHAKKATZ Analogue Source 15 4th November 2004 04:21 PM
Iron, glass, sand and lead. Steve Eddy Tubes / Valves 20 29th September 2004 07:05 AM
Sand sandwich Vikash Multi-Way 48 10th April 2004 04:13 PM
Page generated in 0.09592 seconds (77.95% PHP - 22.05% MySQL) with 11 queries
