determining unlisted parameters
Old 10th June 2002, 10:38 PM   #1
ttvonau is offline ttvonau
Default determining unlisted parameters
Is it possible to find the Le --mH of a driver without manuf.listing it,if so how?Proper xover design without it seems impossible.
Old 11th June 2002, 04:36 AM   #2
Other known as voice coil inductance
Old 13th June 2002, 12:28 AM   #3
kelticwizard is offline kelticwizard  United States
Wizard of Kelts
diyAudio Moderator Emeritus
Just for the heck of it, do you have a specific driver in mind? Maybe we can dig up the inductance spec.
Old 13th June 2002, 01:40 AM   #4
e96mlo is offline e96mlo  Sweden
You can measure the inductance with a LCR-meter.
Old 16th June 2002, 09:55 PM   #5
Thanks guys but mcm finally emailed me with the .33 mh le spec.The driver I was inquiring about was the 55-1200 a 4.5"poly paper woofer .Impresive 94 db ef.and check out this response.All for under $10.00usd.
Old 19th June 2002, 12:40 AM   #6
Wizard of Kelts
That is impressive. For $10, you can't go wrong.
Somebody should clue MCM in about their website. I was getting catalogs from both Parts Express and MCM years ago, and considered them pretty much equal. Parts Express website kills MCM's website though-heck, you can barely even see pictures of the speakers. All I saw was a listing with order numbers.
Old 19th June 2002, 02:00 AM   #7
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Default Excessive parameters
I have the opposite problem:
I bought these Selenium 15" woofers and am working with them in WinISD but the program wants a parameter: Le
The manufacturer lists:
Le at Fs
Le @ 1 khz
Le @ 20 kz
These are in mH if that helps . So since Win ISD only wants one Le which one do I use?
Thanks,
MArk
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 19th June 2002, 04:13 AM   #8
GlennME is offline GlennME
Looks like an interesting speaker. Who makes it?
Glenn
Old 19th June 2002, 04:46 AM   #9
Mcm electronics-55-1200 http://www.mcmelectronics.com/Profil...gistered.jhtml
Check out cheap mcm tower in these forums to see what they can do.
Old 19th June 2002, 04:57 AM   #10
Thanks tt.
Glenn
determining unlisted parametersHide this!Advertise here!
Determining parameters for my 6x9s mpiscool Car Audio 0 19th February 2006 06:11 PM
Determining T/S Specs gjeff80 Multi-Way 22 18th October 2004 12:24 AM
Determining T/S Specs of a sub nuttinbutSQ Subwoofers 1 29th February 2004 06:00 PM
Help, Determining T/S VAS gjeff80 Multi-Way 10 1st February 2004 09:17 PM
Determining Volume Saydee Multi-Way 11 6th December 2003 10:50 PM
Copyright ©1999-2017 diyAudio
