Does anyone have experience using the Scanspeak Flow Resistance Vent. I am planning on using one in a 13 liter sealed enclosure with a Scanspeak 18W/8535 woofer. How about substituting a Flow Resistance Vent for the port in a Proac R2.5 clone (32 liter box)?
D. |
#2 |
In my limited experience, it doesn't have a big effect in relatively low-Q designs; for example, in a sealed Q=0.9 box adding the vent raised Fs and lowered Q but didn't really alleviate the sense of boominess despite taking off a good bit of extension. It was much more effective to simply heavily stuff with fiberglass. I've heard there is more of a difference when we are talking Q ~ 1.3.
My gut feeling is that since the Proac 2.5 is a fairly large box you won't see much advantage going aperiodic--if you want to avoid the port I would just seal it. There is still a good amount of bass. So, I guess my answer is your 13L box is probably a more promising candidate. But I think building a larger box and sealing it is usually preferable if it is an option. |
| Flow Chart for Subwoofer Design | Viking552 | Subwoofers | 23 | 21st January 2007 12:47 AM |
| Wave/Pressure Flow question | johninCR | Multi-Way | 1 | 10th October 2006 07:53 PM |
| Do you think this cabinet restrict air flow | andy2 | Multi-Way | 3 | 6th August 2005 11:36 AM |
| current flow, which direction? | garbage | Tubes / Valves | 16 | 31st October 2004 07:16 PM |
| Newbie Q re physical current flow | dc | Parts | 16 | 14th September 2002 04:40 PM |
| Page generated in 0.05830 seconds (79.33% PHP - 20.67% MySQL) with 10 queries |
