Old 20th August 2004, 01:07 PM   #11
Default EQ and Response
johninCR's comment about flat response is true, as far as it goes.
My current opinion is that a flat response at the listening position in the actual room the speakers are used in is the only way you get to what's on the recording (for good or ill).
I personally use all Rane processors and Crown amps. I use a Rane stereo 31 band EQ and a Rane RTA to flatten the system.
If i was starting out all over again (and the way things go I'm just an eBay sell-off of what I have now away) I'd go with the Behringer "does-everything" (can't remember the model number).
You definitely need the RTA function in addition to the EQ to be successful.
Digital vs analog? In practical terms a non-issue when considering quality componets, aside from the fact that you can obviously get a lot more for less $ going digital.
Old 20th August 2004, 01:20 PM   #12
hurdy_gurdyman's Avatar
Default Re: EQ open baffle or not ?
Originally posted by then_dude
i have also seen in the simulation: if you take a lot of sourcepoints on the surface of the speaker, and you're off axis than the highs cancel each other: that's quite understanding i think. But if you use an open baffle than you certainly need a supertweeter, or may you not look at a speaker conus as radiating at a lot of places at the conus ? Or are a lot of guys not hearing well above 12-15khz ?
then_dude,
If your speaker doesn't have a phase plug, you might consider building one for it. This helps prevent the cancelation/reenforcement modes that can happen with a wide driver being used to create highs. I've done this to several drivers. It really works! The highs are both cleaner and flatter.
Dave
The only thing I like better than the sound of a banjo is the sound of a cat having a shampoo in a flushing toilet!
Old 20th August 2004, 08:51 PM   #13
interesting, the phase plug thing, it's true that the corals beta have this, mine doesn't, i'll google a bit on that one( an also on the site offcourse)
thanx for the digital response, i think i'm gonna buy one, i have just talked with a belgium guy who has it. And for the money you can't go wrong i think.
thanx, greetings
Old 21st August 2004, 02:46 PM   #14
Here's some interesting reading on phase plugs.
http://audioprogress.free.fr/
Dave
Old 22nd August 2004, 01:19 PM   #15
Rudolf is online now Rudolf  Germany
Rudolf's Avatar
Default hope rudolf didn't lost fate in me
Not at all, then_dude!
I now think I understand where you are going. Seems to be the DIY spirit at its best.
And obviously some digital EQ with a RTA function (Behringer Ultra Curve 2496) as wunhuanglo recommended would be a great help.
There is one aspect I would like to comment: There seem to be a lot of people in diy audio who excessively discuss best quality speakers or best reproduction concepts but seldom achieve anything in the real world. What a pity! I understand - if you are laying out big money you are concerned about doing it right.
I personally get much more fun from trying reasonably priced components and getting the most from them. If I fail, at least it doesn´t hurt much. If I win, my competence reaches a new level, from where to start again - and possibly with higher quality components.
Only if I have some running system I know what I miss and where to head to.
The single most effective step forward for me has been accurate positioning of the speakers (and myself) in the room. Cost me nothing except some reading and thinking, but is a very efficient kind of equalisation other people have to buy EQ for .
Keep on, then_dude, you are on a good way
Greetings
Rudolf
www.dipolplus.de
Old 22nd August 2004, 01:40 PM   #16
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Good sanity check Rudolf, and you are right, the theory is a good starting point but there is no substitute for building something and listening to it!
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Does open baffle suffer from baffle step? 454Casull Multi-Way 15 19th May 2012 03:12 PM
Open-baffle baffle length matejS Multi-Way 2 21st September 2010 04:49 PM
Murphy baffle radios [ open baffle ] keithpeter Full Range 10 11th September 2007 07:59 PM
what effect does baffle have on open-baffle system? kappa546 Multi-Way 6 24th January 2006 10:21 PM
Australians- what solid timbers for baffle? (open baffle loudspeaker) tktran Multi-Way 13 29th November 2004 11:09 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
