Old 19th August 2004, 05:03 PM   #1
Default Anything wrong with listening in a room that's too big?
With a suitable amount of acoustic treatment to reduce the magnitude of echoes... say a room that's 4m x 6.4m x 9.6m, or larger.
Old 19th August 2004, 05:15 PM   #2
5th element's Avatar
Id love to have a room that size, so I could put the speakers far apart and me even further away. But yes you would need to treat the room accordingly to keep the reverb time low enough.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 19th August 2004, 05:38 PM   #3
SY's Avatar
That's about the size of my listening room. Echoes are indeed an issue- even with lots of diffusion, I can still hear the effects of slap-echo.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 19th August 2004, 06:14 PM   #4
Are your speakers monopoles, dipoles, or hybrids?
Old 19th August 2004, 06:24 PM   #5
SY's Avatar
Dipole line sources, but I've also used point sources (monopole) in this room.
Old 19th August 2004, 10:08 PM   #6
The more closely spaced low frequency room modes generally give a smoother overall bass response in a larger room and the reflections, if adequately absorbed or diffused, probably will complement most music better than in a smaller room.
OTOH, you may wind up feeling you need need more speaker/amp for realistic levels compared to a smaller room.
Old 20th August 2004, 07:22 AM   #7
Artmaster's Avatar
Send a message via ICQ to Artmaster Send a message via MSN to Artmaster
nice size of room. but you have to suppress resonance as well as possible.
smaller room have another problem.
Artmaster live in www.artmaydan.org.ua
Old 20th August 2004, 05:20 PM   #8
Paul W is offline Paul W  United States
Paul W's Avatar
There are advantages and disadvantages, but one downside is the high system output required to pressurize a large room at very low frequencies.
Old 20th August 2004, 05:53 PM   #9
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
I wish I had a room that big. my room is not bigger than a 4m x4m. although I have 1700 watts RMS.
www.djquan.angelcities.com/secondsys.html
Old 20th August 2004, 09:39 PM   #10
Send a message via ICQ to THOR Send a message via Yahoo to THOR
Default large rooms
my listening room is 4M X 6M with one end mostly open to the kit (4 X 4M).
I face the long wall and listen in the near field@ my desk, The front wall starting 18" down from the ceiling is covered by wool berber carpeting 2M high X 6 M long. the carpet is set out from the wall 2" on a firing strip at the top, and is free hanging, and clears the floor by 2 inches> it covers the big window which faces west, a big problem in the setting sun on days its 120 deg outside in sunny arizona!!
Counting the volume of the window offset , the carpet forms a bass trap of 25 '3 and only takes 2" out of the room! Since im in the nearfield of the Jordans(45") the subs (Sealed) are also 45" from my ears one on each side of my chair, so they are time aligned to the sats Under these conditions , the room effects practually vanish! The music is extremely "you are there" not "they are here" The venue ambiance is almost fully recovered with no interferance from the room The subs pressurize my body not the room , altho at higher volumes they do that too . On heavy pipe organ , the vast volume of the venue is recovered (along with the sound of the blowers! just as tho you were sitting there. Here is an example of not sitting far from the speakers (no need) as the distance to the performers is determined by the venue and recording . I had the same seat at the St. Louis Symphoney for 18 years and I know the sound of that venue. On CDs from them the expierience is erie in its reality . Its as tho i was suddenly back in St Louis , Perish the thought!
If it aint Baroque , fix it !
Nasty Room Resonances in New Listening Room TubeHead Johnny Multi-Way 4 23rd May 2009 11:13 PM
bass is in the wrong room.... SkinnyBoy Everything Else 2 29th January 2004 03:45 AM
What is the influence of your listening room? massive Multi-Way 15 12th January 2003 03:25 AM
Listening room ding Everything Else 4 18th October 2001 01:20 AM
Listening room setup Helix Everything Else 16 6th September 2001 12:49 AM
Page generated in 0.10015 seconds (78.59% PHP - 21.41% MySQL) with 10 queries
