Hi guys. I'm kind of confused about the whole testing thing. I'm thinking about using Speaker Workshop to test my speakers, and I've built the Wallin jig, but I don't have a microphone to do this with. I searched for information about this but found nothing conclusive. Can somebody suggest a cheap microphone setup that'll give accurate results? Do I have to get a preamp? I don't care if I have to build the thing, I just want it to be cheap and accurate!
Thanks! |
#2 | |
diyAudio Moderator Emeritus
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.) |
#3 |
You need a calibrated mic to get accurate results. Some capsules are quite accurate even without calibration.
The measurements on my internet site are done with a calibrated mic and uncalibrated DIY mic (similar capsule). You can see that the results are quite near each other: http://kotiweb.kotiportti.fi/audiovi...mikrofoni.html You need a preamp. The frequency responce of a not_so_good preamp is much worse than the frequency response of an uncalibrated mic. If you deside to DIY, you should be consider this fact. I bought my gear here: http://www.ibf-akustik.de/shop-us/index_us.html EDIT: DIY preamps: http://www.epanorama.net/links/audio...ts.html#micamp http://www.gti.net/wallin/audio/preamp/preamp.html |
#4 |
Hehe, I did come across the Wallin preamp but was intimidated by the fact that it looked so complex compared to the other preamp circuits, and I wanted to understand it. ;-)
But I guess I'll build that today. Have to wait till Monday till the hobby shop opens so I can build my enclosure anyway. Speaking of which, do people build a full enclosure with permanent joints and then mount the crossover through the woofer hole onto the back or whatever, or do they make a removable panel? Thanks! - R |
#5 |
...truth seeker...
Hey parallax,
Yes, you should make the joints airtight, which in most cases means permanent. Inserting the crossover through a woofer hole would be easier (and more often done) than through a removable panel....There's that airtight issue again...hmmm...Even if your enclosure has an opening, a port or vent, you don't want to compromise its effectiveness through leaks in other places. Keep the questions coming. Many of us have been down the same road.
...call me Ed...Special Ed... EnABL kit http://www.diyaudio.com/forums/swap-meet/119852-enabl-kit.html DCB1 parts http://www.diyaudio.com/forums/swap-...ml#post2361098 |
| Microphone suggestion for speaker testing - Thank You in Advance | alvaius | Multi-Way | 68 | 25th May 2012 11:01 PM |
| Using Yamaha receiver calibration microphone for speaker testing? | camshaft | Multi-Way | 0 | 25th March 2008 04:07 PM |
| Speakers in a marine environment | rabbitz | Multi-Way | 9 | 1st February 2005 02:42 PM |
| Class A and the environment | rif | Pass Labs | 17 | 2nd September 2004 07:41 AM |
| DIY Loudspeaker Testing Environment | gregorx | Multi-Way | 14 | 13th July 2004 01:24 PM |
| Page generated in 0.10245 seconds (75.66% PHP - 24.34% MySQL) with 10 queries |
